where to get projectors.
Old Apr 16, 2006 | 09:25 AM
hybridioN's Avatar
all teh single ladiez
for my next mod i would like to put in projectors, preferably with angel eyes. i'm not too sure where to start looking, but i've found some on ebay. however, i remember reading some previous posts about ones you buy on ebay. any suggestions?
i've found these so far:
http://cgi.ebay.com/ebaymotors/01-02...spagenameZWDVW
Old Apr 16, 2006 | 09:47 AM
Falken-Maxima's Avatar
Theres ones on the custom maxima website i think
Old Apr 16, 2006 | 10:09 AM
Mass_Media's Avatar
Mass_Media™
Can't we retro fit some bmw ones like the 4th gen people do? I thought that someone had done it (Grammer?)
Old Apr 16, 2006 | 11:25 AM
hybridioN's Avatar
the ones on CE and the one's on ebay are identical...or atleast they look it.
Old Apr 28, 2006 | 09:54 PM
Maxima@usa.com
the ones on CE, the AEs are kinda yellow compared to the ones I purchased from Ebay... the rings are more bright.
Old Apr 28, 2006 | 10:20 PM
Maxi113's Avatar
Buy mine I am selling them since I am getting skyline hls now :P
Old Apr 28, 2006 | 10:45 PM
96blkonblkse's Avatar
so how would these work with my 02, would my HID's still work?
Old Apr 28, 2006 | 11:11 PM
808MAX-SPEC's Avatar
I copied this off of my cardomain site cuz I didn't want to rewrite the whole thing. I may be missing some details but this is what I would do if i had a 02/03 Maxima.
2002-2003 RETROFIT ADVANTAGE - The one ebay projector retrofit advantage that the 2002/2003 Maximas have over the 2000/2001 is the electrical setup. The 02/03 OEM headlights utilize a HID low beam and a 9006 high beam, powered by via the ballasts and ignitors. Since the 2000/2001 uses a H4, dual filament bulb which produces a low and high beam, a custom wiring harness would need to be made to power the bulbs in the retrofitted ebay projectors.
So if I had a 02/03 Maxima and wanted to power the retrofitted ebay projectors, all I would have to do is replace the D2R bulbs with a D2S* bulbs. I would also have to replace the 9006 bulb with a H1. Because the H1 bulb is a single lead, I would have to modify it in such a way to power the 9006 bulb. Instead of rewiring from a 9006 to an H1, another option would be to bore out the hi-light reflector bowl and creating a bulb holder for the 9006 bulb.
Old Apr 29, 2006 | 03:42 AM
SoonerFan's Avatar
Cletus
projectors suck almost as much as the endless threads about them
Old Apr 29, 2006 | 01:47 PM
You might be better getting it off of ebay. If you do get it from this seller. Symmic makes these headlights.
http://cgi.ebay.com/ebaymotors/NISSA...QQcmdZViewItem
Also, as for your angel eyes, you can either do the LED swap per Dr. Roy's write up or consider getting CCFLs.
http://cgi.ebay.com/ebaymotors/CCFL-...QQcmdZViewItem
Not sure if I'm going to get these but this set is the cheapest I've seen.
goldtooth
May 12, 2007 10:01 PM
EteRnity059
May 2, 2007 04:16 PM
jvelos3
22
Jan 31, 2007 08:05 PM
