Headlight question?
Old May 2, 2006 | 07:11 PM
STyLeZ4o1's Avatar
Headlight question?
ok I'm having a professional install my umnitza dde's. He told me that the headlights might fog up after he takes it apart n puts them back together. Said water might get in and what not. Has this happen to anyone who has taken apart the headlights? Is there anything he can use to seal the plastic back into good place? Thx guys
Old May 2, 2006 | 07:16 PM
MIXXMAX's Avatar
No, they will not fog up if you seal them up correctly. Just make sure the glue is hot and gooey, and work fast. The glue dries pretty quick once you take it out of the oven. I just used the same glue that was on the headlights. I haven't had any problems with any moisture getting in.
Old May 2, 2006 | 07:23 PM
Dr. Roy's Avatar
you can usualy reuse the sealant on the lights, but if you want to be safe there is always Nissan OEM rubber butyl headlight sealer
Old May 2, 2006 | 07:24 PM
STyLeZ4o1's Avatar
........thx guys
Old May 4, 2006 | 11:59 AM
STyLeZ4o1's Avatar
I just called the stealership and they told me they never heard of it. Is there a part number for this or something? or where can I by this at?
Old May 4, 2006 | 12:22 PM
djfrestyl's Avatar
Suspension Yoda
The part number is right on the box in the picture.
Old May 4, 2006 | 01:44 PM
STyLeZ4o1's Avatar
yea he said theres no such part #. Does that say B6553-89915 or 86553-89915?
Old May 4, 2006 | 01:49 PM
djfrestyl's Avatar
Suspension Yoda
Did you confuse the B with an 8?
Old May 4, 2006 | 01:50 PM
STyLeZ4o1's Avatar
I think so
Old May 5, 2006 | 02:40 AM
flipnautika's Avatar
hmm so u just rubbed all the chrome part off with a wet towel? no paint needed? that looks freakn aweseom tho!!!
Old May 5, 2006 | 09:18 AM
Edward Lee's Avatar
I got the Butyl in light grey if you need it.
Old May 5, 2006 | 11:20 AM
STyLeZ4o1's Avatar
They come in different colors? My car is black but i dont think the butyl is noticable. How much btw?
I just called nissan and they told me they were used for the taillights. Is it the samething?
Old May 5, 2006 | 02:25 PM
Edward Lee's Avatar
How much does Nissan charge?
Old May 5, 2006 | 03:45 PM
MAXRB8's Avatar
I'm with MIXXMAX on this, I just did this mod a couple of weeks ago and with the right oven temp and time the glue softens up enough to make a perfect reseal, I've had no fogging issues since and I went into one of the headlights a second time.
BTW I didn't know there were professional Maxima headlight crackers!
Old May 5, 2006 | 04:40 PM
MIXXMAX's Avatar
Yeah, that black butyl is for the tail lights. This is used to "seal" the tailights to the frame of the car. The grey is for the headlights, but that is glue , not like the "sealant" for the tailights. Also, I'm not sure if Nissan even sells the glue for the headlights because they were'nt made to be re-opened, so that is why it's probably not even stocked as a part number. Hmmmm...... Like I said before, just re-use the glue from the headlights and you'll be fine.
Old May 7, 2006 | 05:56 AM
ctrent86's Avatar
I took my headlights apart three weekends ago. If you do it right you can reuse the seal. I didnt add any additional butyl. Just make sure you have made teh glue sticky enough and it will seal fine no condesation. Also doing this mod is very easy there are countless write-ups on it. Just give it a go for yourself. The more you work on your max the more you love it.
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
