Question about AT & MT
Old May 3, 2006 | 04:52 AM
00Max00's Avatar
May be a dumb question to the experts here. As we know on manual, unless you push in the cluch pedal or shift to N, the tranny is always engage the engine. So when is auto tranny disengaged from engine? N or just leave it on D while release the gas pedal.
Old May 3, 2006 | 04:56 AM
SoonerFan's Avatar
Cletus
torque convertor
Old May 3, 2006 | 05:54 AM
00Max00's Avatar
Oh no. Actually I meant is there any engine brake on AT while coasting?
Old May 3, 2006 | 09:14 AM
MaxBoost925's Avatar
Drug Money
try this, while moving pretty fast, "downshift" into Low gear.
you should feel the "engine braking" on your automatic.
Old May 3, 2006 | 09:26 AM
MaxKlinger's Avatar
Don't actually do this. If he doesn't know what he's doing, he's likely to damage his transmission.
Yes, automatic transmissions can do "engine braking" just like a manual. However, I would generally recommend against it, especially if you aren't intimately familiar with the car and the transmission. Brakes take an hour and $60 to change. Transmissions cost thousands of dollars to have changed out.
Anyway, you can downshift your auto trans just like a manual. If you click your O/D off button, you'll lock out 4th gear from engaging, which holds the car to using only the first three gears. Generally speaking, if you're under low load or coasting at speeds greater than 40mph and you click O/D off, you'll feel some engine braking as it downshifts into 3rd.
Old May 3, 2006 | 11:01 AM
FriscoMaxima's Avatar
try this... get on the highway going about 80mph and QUICKLY pull the gearshift lever towards yourself util it is in "1". It will quickly stop your car... ...forever...
Old May 3, 2006 | 02:05 PM
carsarecool's Avatar
Haha, Maximas probly have the 1st gear lockout- probly second too to prevent that exactly from happening. I had a pontiac before that a friend tried to shift in 2nd but ripped it into first at like 65 i was like ohh **** but it stayed in 2nd. Nissan's probly smarter than to let you shift whatever you want, also has anybody ever had that fail-safe thing come on? You know in the manual where it says if the trans is used in excessive wheel spinning and subsequent hard braking, the O/D light flashes and its in fail-safe? Sorry about all the q's, i have a stick
Old May 3, 2006 | 03:34 PM
HighMiles's Avatar
This is a pet peev of mine: Why do people downshift manuals every time they come to a stop? (accept when going down a steep grade). clutches/transmissions cost so much more than a brake jobs.
and I shift enough without shifting back threw almost every gear every time I come to a stop.
I see almost no reason to ever doo this.
Brent
Old May 3, 2006 | 03:41 PM
Drug Money
Brent
They want to be cool.
What I do is i clutch-out and shift to neutral. Then I just brake. $Transmission > $Brakes.
Old May 3, 2006 | 06:54 PM
NmexMAX's Avatar
dot dot dot ...
P and N.
Some aspects of the auto Maxima are idiot proof... it will not downshift if the speed is too high for the selected gear.
Old May 3, 2006 | 07:05 PM
Y2k2maxse's Avatar
yea and also for anyone thats wondering 2k2+ autos will not let u shift into reverse or park if ur going over about 3MPH and dont have ur foot on the brake...thank god for that or my tranny woulda been gone right now.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
