2000 Maxima SE vs. 2000 VW Passat 1.8T on Dyno
Old Jun 17, 2001 | 07:19 AM
madmax2k's Avatar
The tale of the tape.......
The Passat is modded with a KO4 turbo, chip, and exhaust. The Max has a Cattman Y-pipe and CAI. Dynorun.021 is the Passat, and Dynorun.011 is the Maxima. I got my a#@ kicked except before 2700 rpm and after 5500 rpm.
http://homestead.juno.com/madmax2k/f...assatvsmax.bmp
Old Jun 17, 2001 | 07:53 AM
Max_Gator's Avatar
And, pray tell, what did that translate into on the street???
Old Jun 17, 2001 | 10:13 AM
MardiGrasMax's Avatar
How much boost is he running? 14.7psi or greater?
Old Jun 17, 2001 | 10:23 AM
madmax2k's Avatar
Havent had a chance to find out! The last time we met (at the track...you were there!) he didnt have this setup. Im guessing on the street Ill be toast now if we both launch the same.
Old Jun 17, 2001 | 11:11 AM
AznWontonboy's Avatar
wow, looks like VQs dyno charts have a pretty flat curve.. neone else no a car that hs that? i never seen a v8 chart.. is that flatter?
Old Jun 17, 2001 | 11:40 AM
Max_Gator's Avatar
I'm not very good at comparing performance from dynos (unless it's a lingenfelter stroked 427 C-5 compared to a maxima!) but . . . if you launched well and kept your shifts at red-line you'd have more hp to the wheels once you got past 5500 in first. Looks like he'd get you out of the hole, though.
BUT - the way you launch . . . he might not have such an advantage!
Old Jun 17, 2001 | 12:36 PM
tomz17's Avatar
249 torque??? is that normal??
Old Jun 17, 2001 | 08:38 PM
madmax2k's Avatar
For his mods, yes.
Old Jun 17, 2001 | 10:34 PM
PhatGuy
I believe you are putting out a lot more than that dyno shows since you have a true CAI. The cooler air flow coming in as you are accelerating is going to give you more power for sure.
halfpol
Oct 17, 2022 12:16 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
halfpol
Aug 5, 2015 08:24 PM
