dim corners... why?
Old Jun 18, 2001 | 05:01 PM
ToYLeT902's Avatar
JET Speed Lab
just wondering how come when i put polarg m-14 bi hybrid super whites in the corners up front, when the lights are on, they look dim, unless i use my signals where they blink really bright?
Old Jun 18, 2001 | 06:47 PM
mbcp_tdogg's Avatar
Hmmm...that's interesting. I use the M-9s for my front corners and they work just fine. Wonder if that's the reason?
Old Jun 18, 2001 | 08:02 PM
mbcp_tdogg's Avatar
An update and a correction...
The correction is that I use M-12s for the front, not M-9s.
The update is that the M-12s emit a higher intensity light than the M-14s that you are using (35W vs 21W) so that goes to explain your observation. Hope this helps.
Old Jun 18, 2001 | 09:06 PM
ToYLeT902's Avatar
JET Speed Lab
time to buy some M-12's then
Old Jun 18, 2001 | 09:13 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Personally, I like the look withOUT corner lamps. Mine just blink amber(no running lamp), so you only see my Super Whites. Plus, you don't have a problem trying to match the corner lamps with the headlamps.
P.S: Just put a piece of electrical tape over one of the two "knubs" on the bulb and then reinstall to see what I'm talking about.
Old Jun 19, 2001 | 01:17 PM
maximlover's Avatar
i have the piaa xtreme white and have the problem of it being dim except when blinking. let me know if the increase in wattage makes a difference. i have panasonic HIDS and wondering if that is so bright that it makes the corner lamps dim.
sam
Old Jun 19, 2001 | 01:25 PM
mbcp_tdogg's Avatar
sam
You got HIDs? Lucky guy! That can definitely be a reason why your corners look dim.
Old Jun 19, 2001 | 08:17 PM
maximlover's Avatar
another question..
i was wondering if rewiring the clear corners to blink with the signal may be causing it to be dim?
Old Jun 19, 2001 | 08:53 PM
ToYLeT902's Avatar
JET Speed Lab
another question..
nah it wont dim it
Old Jun 20, 2001 | 08:22 AM
maximlover's Avatar
nah it wont dim it
ACTUALLY I THINK ITS BETTER THAT ITS A LITTLE DIM (ITS NOT ALL THAT BAD) - WON'T GET BUSTED BY 5-0 FOR NOT HAVING AMBER COLOR IN THE CORNER LAMP.
Old Jun 20, 2001 | 08:31 AM
ToYLeT902's Avatar
JET Speed Lab
im going to get busted sooner or later or my rear signals. they caused a blind person to squint there eyes while my signals were on
gavin68
Sep 18, 2021 12:36 PM
kjlouis
Sep 14, 2015 11:22 AM
