Random missfire
Old May 30, 2006 | 07:32 AM
Jay_pee99's Avatar
Random missfire
For about the past week i keep getting a random missfire code poping up. I can fell the car sputtering under light acceleration, but it seems to clear up under heavy acceleration. I checked my spark plugs, and they were fine. 3 of the were alittle loose so i tighten them down, i also clean the intake manifold and it's still doing the samething. One of my coil packs was soaked in oil b/c one of gaskets around the spark plug cylinder was busted, but i'm not sure if thats the problem. Can anyone help me out?
Old May 30, 2006 | 10:02 AM
Supreme Allah's Avatar
Are any other lights on besides Check engine?
Old Jun 1, 2006 | 05:46 AM
Jay_pee99's Avatar
nope, CEL is the only light on
Old Jun 1, 2006 | 06:28 AM
MAXRB8's Avatar
I had that code and it turned out to be a bad coil pack, which one? I don't know as I got a deal from Steven88 on a complete set of working used one's problem gone. The oil in the plug ( which I've had before also) shouldn't caause the random missfire if anything it would be a cylinder specific code.
Old Jun 1, 2006 | 06:44 AM
GBAUER's Avatar
probably a bad coil. Take it to Redline and have them pull the code instead of autozone. Redline has a much better code reader that can tell which cylinder is misfiring. Autozone's reader just tells you that one of them is bad, not which one.
Old Jun 1, 2006 | 07:02 AM
MAXRB8's Avatar
Actually it may not , after using my OBDII scanner and only getting the P0300 ( random miss fire ) I took it to my mechanic who has a mega machine thinking it would isolate the coil, but nada. There are various ways to isolate it. Here's one way: http://forums.maxima.org/showthread.php?t=451830
Old Jun 1, 2006 | 07:30 AM
GBAUER's Avatar
you're right: could also be a fouled plug (checked) or bad connection. Regardless, he needs to get it checked by a reader that will tell him which cylinder is misfiring.
Old Dec 28, 2006 | 12:04 PM
housecor's Avatar
I'm experiencing the exact same symptoms. jay-pee, what'd you end up fixing? I'm trying to decide if it's my MAF or a bad coil - I suspect it's a bad coil. I've gotten multiple p0300 codes, but I have gotten a code for a misfire in cylinder 6 once.
Old Jan 21, 2007 | 08:55 PM
housecor's Avatar
Bump hoping for a response from jaypee/others. Also, an easy way to test for a bad coil if you're getting a SEL for a particular cylinder is to just swap the coil to a different cylinder. If the code changes to the swapped cylinder, obviously the coil is bad.
Old Jan 21, 2007 | 09:00 PM
elgrande2003se's Avatar
Ended up being a bad maf when mine did this. It was light sputtering on light loads and fine under wot. Then one day it completely fell on its face.
Old Jan 22, 2007 | 07:16 AM
platinum03SE
i got a random misfire once or twice. cleared it and they never come back.
Old Jan 22, 2007 | 10:00 AM
wngan9447's Avatar
Chicken Feet Croo!
I envy people that have specific codes onto which cylinder was misfiring. Mine wont misfire for more than 10 seconds and i don't feel like changing all the coils (money issue). I've tried the resistance test, but didn't have a DVOM with 20ohm option. :sigh:
Old Jan 22, 2007 | 10:35 AM
Bensmax00's Avatar
if there is oil on the coil packs that could be the problem--if the coil has oil on it the spark could be getting lost through the oil--electricity travels the least path of resistance and oil would be the least path, so the spark would get lost and that cylinder would misfire--now to have a random misfire code there are 7 possibilities p0300-p0306. and if you have a multicylinder misfire code-if you haven't replaced your coils you should otherwise I would run a power balance test to see which cylinder(s) are misfiring and check them out but most people dont have access to the consult 2 unless you work at the dealer
Old Jan 22, 2007 | 05:34 PM
jawwaad05's Avatar
im having a similar problem i keep getting cylinder 2 misfire and i thought the studder in low rpms was because of the fuel cut issue also my CEL blinks sometimes usually whn i go over about 3200 and then stops and does it again ... wat do i need to get raplaced?
Old Jan 22, 2007 | 05:35 PM
jawwaad05's Avatar
oh and i replaced all my sparkplugs but it still happens
Old Jan 22, 2007 | 06:07 PM
dmaljunk's Avatar
why don't you just fix that oil leak and watch the car for a while. You need to replace spark plug tube seal, you can get them together with valve cover gaskets and do the whole thing since you will be removing the rocker cover to get these tube seals in.
Old Jan 22, 2007 | 10:40 PM
5thgenmaxima's Avatar
Pull your cylinder 2 plug and inspect it. Also inspect the porceline for hairline cracks. Replace the plug and switch coil #2 with coil #4 or 6. If the problem goes away it was your plug. If you start getting p0304 or p0306 then your coil is bad. Also if you are getting any primary ignition system codes (p1420 IIRC) then it's not likely a plug issue, most likely a coil.
Old Jan 23, 2007 | 09:57 AM
Nismo98's Avatar
If you are getting a misire and your checked or replaced the spark plugs & the coils the next thing you should look into is having engine compressions done. Reason why I am saying this is because I have same problem on my 3.5 QX4 where I am getting 0303 cylinder 3 misfire. I had compressions done yesterday, and I am in trouble. The range where cylinder comression should be on 3.5 QX4 is 130-168 psi, on cylinder 3 I am not even hitting 90 psi. In this case to solve the problem you'll be looking at 20 hours of labor to replace the rings or shopping for a new engine.
Andrei
Old Jan 23, 2007 | 05:12 PM
Jay_pee99's Avatar
Sorry for the late response, not really on here that much anymore. I'm not exactly sure but if this was the problem but, my back valve cover was leaking oil into one of the spark plug cylinders. After i changed the valve cover the problem went away. By the way, oil had been leaking into that cylinder for over a year.
Old Apr 3, 2007 | 12:14 PM
SoonerFan's Avatar
Cletus
well i just got the generic P0300 Multiple Cylinder Misfire
funny thing, the car is driving fine. i reset the code and i will see if it comes back. if it does, im going to start with the plugs since im pretty sure they have never been replaced.
pretty sure my oil burning engine messed the plugs up.
Old Apr 3, 2007 | 12:24 PM
SoonerFan's Avatar
Cletus
just found this about the P0300 that doesnt tell you a cylinder...interesting.
Random misfires that jump around from one cylinder to another also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
Old Apr 3, 2007 | 12:43 PM
bert's Avatar
I had a misfire code (P1420?) around New Years, with the wonderful CEL. The car was running OK except for slightly difficult starts when the engine was hot.
A couple of weeks ago the CEL decided it had had enough and turned off. Still giving the slightly difficult starts but other than that, no problems. (and no new coil packs!)
Before Christmas I did have the MAF replaced and the computer updated due to the updated MAF specification.
Old Apr 3, 2007 | 07:54 PM
OutMaxxed's Avatar
Good that you got the problem fixed .
But to anyone with the problem..
Does the car have trouble starting up? Like when you crank, it doesnt start sometimes? If so I would say it was a coil pack. When it happened to me it was a bad coil and a bad plug.
Does the the car shift smooth in all gears? Like do the rpms hang a little when the gear changes? IF it hangs id say it were a MAF problem
Old Sep 6, 2010 | 01:53 AM
ef9's Avatar
ef9
Sorry for waking this thread from the dead. But I am looking at a 1998 GXE and it has the P0300 code which says it's a random misfire. The FSM says it could be a lot of problems, not just coil pack(s).
I'm contemplating on purchasing this car and using it for my daily driver, that is, if I can repair it.
The car does have trouble starting up (as Outmaxxed stated above). The car runs terribly rich.
Stan
Old Sep 6, 2010 | 06:43 AM
Grand_hustle17's Avatar
Yea, I'm getting a slight misfire at idle also ill just change my plugs and see what happens
Old Sep 15, 2010 | 04:03 PM
bgsl1ck's Avatar
I have a P0300 and a bad misfire car sounds sick change coils and plugs can anyone help..
Old Sep 15, 2010 | 04:09 PM
any o2 sensor codes?
Old Sep 15, 2010 | 05:36 PM
bgsl1ck's Avatar
bank 1 sensor 1 low heater circuit
Old Sep 15, 2010 | 08:44 PM
Night_raiders's Avatar
I had the same problem at one point it was a random misfire then specific cylinders ended up replacing some coils and plugs. still didnt fix the problem then i found a TSB where a wire in the wiring harness that wraps around the right corner of the motor was broke which was causing the engine to misfire. you can always try wiggling that harness on the right side(passenger side).
Old Sep 15, 2010 | 10:54 PM
bgsl1ck's Avatar
thanks
Old Sep 15, 2010 | 11:13 PM
tedo007's Avatar
faster than you think
I had CEL for misfire change the all the spark plugs. Still didn't do anything. Finally I had to spend some real money got the COILS changed and now no more misfire. Loving the the dashboard without CEL.
Old Sep 15, 2010 | 11:51 PM
bgsl1ck's Avatar
did that already
Old Sep 16, 2010 | 08:46 PM
bgsl1ck's Avatar
Can sombody help bad missfire changed coils and plugs and the only other code was an O2 sensor bank 1 sensor 1 low heater circuit. Car starts but even at idle it sputters.
Old Sep 21, 2010 | 09:50 AM
KingZeke's Avatar
My 99 is sputtering at light acceleration or when trying to accelerate in passing. My CEL has not come on, I have replaced coils in the passed and it feels like something like that. I am going to change the spark plugs first with Autolite Platnums. Hoping to see if I can notice any coils that don't look quite right. From everything I have read, I seem to be going down the right path. Engine Coils are the only things I have ever had issue with on this car.
Old Sep 22, 2010 | 07:23 AM
maximal01's Avatar
im having the same issue but i have a o2 sensor rear bank under threashold, i spray throatle body cleaner in the hoses and it goes away after a minute im gunna get some seafoam today ill let you know how it works out
ps. this happens about once a week?
msellas
Sep 23, 2015 09:16 PM
lrb6805
Sep 17, 2015 04:49 PM
ballerchris510
Sep 10, 2015 09:35 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
