Passenger Window switch LED replacement
Old May 30, 2006 | 01:55 PM
frankd121's Avatar
Has anyone replaced the passenger window switch light with an LED? I've got the driver's side and passenger door lock switches finished, but am not sure how to put in an LED for the window switch. Any input would be appreciated. (Pictures would be nice too)
Old May 30, 2006 | 02:43 PM
MIXXMAX's Avatar
You have to pry open the switch to access to the LED that is already in there. Once you open it, a "see-saw" like piece of metal and some tiny metal ***** will fall out. Make sure you don't lose these. This is what makes the switch open and close the window...up and down. Anyway, once you have the switch open, remove the ugly green LED and solder a new one in there of your choice. Reverse the procedure for install.
Old May 30, 2006 | 02:49 PM
frankd121's Avatar
The green LED is in some kind of white plastic mounting piece. Can you just push it out?
Old May 30, 2006 | 03:23 PM
MIXXMAX's Avatar
Yes, it just pulls right out.
Old Jun 1, 2006 | 10:14 AM
BigL0U's Avatar
How bout that how-to about the positive and negative ends on the LEDs ... in any case the full write up with those references...
Old Jun 1, 2006 | 01:58 PM
MIXXMAX's Avatar
Not quite understanding what you're asking....but if you want to know which is negative or positive on LED's...look inside the LED, the "flat-type" blade inside the LED is the negative lead.
Old Jun 1, 2006 | 02:16 PM
frankd121's Avatar
If anyone's looking for a write up, here's the one that i ended up finding and using:
http://www.cardomain.com/ride/305093/7
Old Jun 1, 2006 | 03:54 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
normally on the led... the longer end of the led is the positive...
Old Jun 1, 2006 | 04:33 PM
MIXXMAX's Avatar
Yeah, only when the leads have'nt been clipped. But, an easier way to tell and to be sure is like what I said in my previous post.
Old Jun 1, 2006 | 07:40 PM
xTeCaOx's Avatar
a quick and easy way to tell the positive and negative is just take out your battery out of your remote for your car and connect it to the led and if one side doesnt work flip it over and then when that works just look on the battery to see which side is positive and then remember which one it is long or short prong..................
Old Jun 1, 2006 | 07:53 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Correctomundo.
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
mpbclutch33
Aug 21, 2015 06:09 AM
george__
Aug 18, 2015 07:06 PM
kjm900r
Aug 5, 2015 07:14 AM
