Power window not working
Old Jun 3, 2006 | 07:35 PM
dmplus's Avatar
My wife rolled down the driver window, and tried to roll it back up, it started coming up very very slowly, then stopped, and dropped back down an inch or so, and now wont go up or down.
It had been getting flakey (rolling up slow, taking a few tries before it even started to roll up) every once in a while.
I took the door apart and looked at the mechanism, everything seemed in tact, nothing broken. So i dont know if it's the motor or not. If it is, what's the best way to get a replacement and how hard is it to replace, it looked a little difficlut, and i'm worried about the cable, and tension etc..
Thanks for any input you have
Old Jun 3, 2006 | 08:23 PM
djfrestyl's Avatar
Suspension Yoda
You need to reset the positions on the window. There should be a red button in the door. Check the stickies for the procedure.
Old Jun 4, 2006 | 06:35 AM
dmplus's Avatar
I went through the stickies, even a search, and cant find what you are talking about. I'm probably just blind or something :-)
Old Jun 4, 2006 | 07:03 AM
djfrestyl's Avatar
Suspension Yoda
This should do it
http://forums.maxima.org/showthread.php?t=426162
Old Jun 4, 2006 | 07:56 AM
dmplus's Avatar
Ok i read it, and it's good info, but I cant get the window back up to start the reset sequence. Anyone know how to get it back up? It's mostly down, and will not go down the rest of the way or back up at all.
Old Jun 5, 2006 | 12:40 PM
dmplus's Avatar
Any other ideas? From anyone? I really hate to take this to the dealership.
Old Jun 5, 2006 | 01:37 PM
djfrestyl's Avatar
Suspension Yoda
Use the palm of your hand and slide it up...it may work.
Old Jun 6, 2006 | 07:13 AM
Clayton's Avatar
Thank you so much for posting the link to thread with the write up on how to fix the auto rollup issue. I was just about to post a thread asking about it myself.
Old Jun 6, 2006 | 12:01 PM
dmplus's Avatar
Ok i've tried getting it to come up with my hands but it doesnt want to budge, but i also dont want to break anything. Could the motor have siezed? Would the window still move if that awas teh case, i cant manually move the window up or down.
Old Jun 6, 2006 | 12:04 PM
djfrestyl's Avatar
Suspension Yoda
If you buttons still can control the window then no the motor has not siezed.
Old Jun 6, 2006 | 08:20 PM
dmplus's Avatar
Motor doesnt move, window doesnt move, nothing moves, manually or with switches :-) It's very frustrating!
Old Jun 7, 2006 | 04:36 AM
djfrestyl's Avatar
Suspension Yoda
Did you check the fuses?
It's possible the cable came off the track or the motor just went..time to call a junkyard
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
