coilovers...
Old Jun 12, 2006 | 09:33 PM
maxS
coilovers...
did rears last saturday, just a few pictures...
well, the thing is actually MUCH shorter then i expected... i used a jack to lift the rear beam up in order to get the lower bolt in.
even with this drop the front end on teins is like 10 mm lower then the back.
but this was the first try, i ended up with unscrewing the lower part of the strut; takes 10 full turns to make it 20 mm longer, so now it seats a bit less then an inch higher, but still not as high as it was when i had teins in there.
i can't really comment the handling at this point, the front is not done yet.
Old Jun 12, 2006 | 10:26 PM
whazzzzuup's Avatar
Nice work! What spring rates do you have on the setup?
Old Jun 13, 2006 | 12:00 AM
ak_max02's Avatar
That looks good man where do you pick those coilovers at? I've been lookin everywhere.
Old Jun 13, 2006 | 12:03 AM
MaxBoost925's Avatar
Drug Money
K-sport Ftmfw!!!111111
Old Jun 13, 2006 | 12:11 AM
steven88's Avatar
Need A Light?
i love ksports...did vasily give you his rims? or you have a pair of SSRs as well?
Old Jun 13, 2006 | 11:32 AM
OH2kblackMAXX's Avatar
HELL YEAH MAN!!! i just did mine last night and my car is frikin slammed....i was in a hurry so i didn't take the tiime to adjust them, but i'm tuckin little less than quarter tire in the rear.
o and i am not sure where you picked these up from, but i got mine from jlbmotorsports.com. i paid a little less than 700 SHIPPED
Old Jun 13, 2006 | 12:16 PM
GBAUER's Avatar
I've spent the last three weeks adjusting my D2's so that the ride was perfect. Something I noticed was that on the rear's, I had to pre-load the springs with the locking nuts by a good 1/2". Now that I did that and don't have the front too low, my car is as smooth as stock, but as stiff as anyone in their right mind would want it. Just some advice.
Old Jun 13, 2006 | 04:31 PM
doublea's Avatar
While your at it I strongly suggest that you buy some Energy Suspension coilover insulator, there like 8$ per pair but it make a whole world of difference. Once install properly your coilover will be much quiet and it also soften the ride, because there is no more metal on metal. How do I know ? I've been running the D2 for almost 2 year now and trust me your happyness will quickly become a nightmare. PM me if you want details.
Cheers
AA
Old Jun 13, 2006 | 05:56 PM
maxS
no, i did not take his, i've got a set for myself, but these are a bit smaller...
do not know what rates the springs are...
rears have rubber insulators on the top of the springs, but nothing on the bottom. I have not heard any noises tho. As for the ride, the rear feels firm/a bit harsh (i still have s-techs in front), the car turns with less effort, i would say it's almost neutral in balance .
here is another angle:
Old Jun 13, 2006 | 06:52 PM
steven88's Avatar
Need A Light?
hey maxs, those are 4th gen ksports?
Old Jun 13, 2006 | 06:59 PM
vsamoylov
im jealous now i want some coilovers. time to get the fronts put on.
Old Jun 13, 2006 | 07:41 PM
maxS
those are 5th gen, why would i get 4th?!
Old Jun 13, 2006 | 07:43 PM
vsamoylov
so i can take them from you later on.
Old Jun 13, 2006 | 08:38 PM
steven88's Avatar
Need A Light?
becuz, as far as i know, 5th gen ksports do not come with rear hats...you must re-use your stock ones...same with D2 coilovers
it's always been like that...UNLESS, ksports recently changed the design...but as far as i know, they are still the same old design...and you must reuse your rear hats....the one you have in your picture already includes a rear hat so I asked if you got a 4th gen kit (cuz 4th gens come with the hats)
Old Jun 13, 2006 | 09:29 PM
maxS
they must have changed it, since 1. they came with the top plates/hats, 2. 4th gen hats are way different from 5th gen and can not be used here unless machined/modified. well, that can be done
Old Jun 13, 2006 | 09:34 PM
DrKlop's Avatar
Driving is the next best thing
make triple sure that you got the right set. There was at least one case where someone received a 4th gen set.
Old Jun 13, 2006 | 09:41 PM
steven88's Avatar
Need A Light?
there was a case where someone received the 4th gen strut...and he has a 2k...its in the big ksports thread IIRC...check it out...he said its a direct bolt on
Old Jun 13, 2006 | 10:19 PM
whazzzzuup's Avatar
So based on the information from this thread, either that is a 4th gen rear coilover or a revised 5th gen rear coilover with top hat? Will the front/rear 4th gen coilover fit a 5th gen with no modifications? That just gives the 5th gen guys more buying options.
Old Jun 13, 2006 | 10:24 PM
steven88's Avatar
Need A Light?
you are correct....it could possibly go either way....either ksports have UPDATED their 5th gen coilover lineup...and now include top hats for the rear...or he could have gotten a 4th gen setup...which is a direct fit according to that one guy in the thread...
i'm not sure if the fronts would fit...but its an issue going on with the ksports thread...check it out
Old Jun 13, 2006 | 10:26 PM
whazzzzuup's Avatar
Are your shocks blown? If not, I might have an interested person to purchase them from you.
Old Jun 13, 2006 | 10:34 PM
AceofSpds's Avatar
wat
I would send ksport an email or call them or something to ask about the struts.
Group Deal Forum Buddy
Old Jun 14, 2006 | 04:50 PM
maxS
let's keep it simple: 1). i got rears with tops/hats installed on the struts. 2). 4th gen tops/hats (NOT shocks/struts itself) WILL NEVER FIT IN without extensive machining of ether hats or strut seats in the car. These came completly assembled and went in without any problem. Something tells me i got the right ones. As for the fronts, it's going to be "part 2" some time next week.
Old Jun 14, 2006 | 06:40 PM
maxS
update drop (after i rased it 20mm):
here is what's going to happen to the front:
Old Jun 14, 2006 | 07:11 PM
BRINKLEY's Avatar
sigh, wish I would have went this way instead of the h-tech/ illumina setup.. never fails......
Old Jun 14, 2006 | 07:31 PM
DrKlop's Avatar
maxS, check this out:
http://forums.maxima.org/showpost.ph...postcount=1133
and this:
http://forums.maxima.org/showpost.ph...postcount=1139
and he actually installed it.
Old Jun 14, 2006 | 07:38 PM
vsamoylov
the 4th gen hat in the rear will not work on a 5th gen no way.....
Old Jun 14, 2006 | 08:08 PM
steven88's Avatar
Need A Light?
i guess it worked for him
Old Jun 14, 2006 | 09:40 PM
maxS
Originally Posted by DrKlop
i see what's going on... that i can understand. He's got 4th gen set which has rears with 4th gen hats of course, but instead of using ksports alu hats he re-used oem 5th gen hats... all it takes is removing the nut (center) on the strut, this way the strut comes out, but the hat stays in place. Then either 4th gen or 5th gen strut (with no hat) can be installed. That apparently works, and that's exactly what i did when my brother had 5th gen illuminas/springs in his '96. But... on regular struts there is a dif between 4th and 5th gen design, top end of the shaft is difrnt, bottom seat for springs (and springs accordnly) is difrnt dia also. Do not know if ksport struts itself differ for 4th and 5th gen.
Old Jun 14, 2006 | 10:20 PM
DrKlop's Avatar
but he said that he did not use his stock hats.
Old Jun 15, 2006 | 04:18 PM
maxS
well, look on the picture of his ksports in the box... I personally do not see any hats for the 2 rear struts . What did he use? Anyway, mine are in, not much to complain about.
Old Jun 15, 2006 | 05:07 PM
super6's Avatar
congrats, im sure the handeling is great....btw, i love those wheels
Old Jun 15, 2006 | 05:17 PM
NewMaxSe's Avatar
How did you manage $700 shipped when they are listed for $1150 on their website??
Old Jun 15, 2006 | 05:47 PM
d3van's Avatar
I'd like to know that too. I emailed them but got no reply...
ZzzZSlow
Feb 26, 2014 05:42 PM
95pearl
Feb 3, 2013 10:20 AM
I3LAZEN
Apr 18, 2009 04:34 AM
