Quick mods
Old Jun 17, 2006 | 09:59 AM
01-GLE's Avatar
Quick mods
what cheap mods could i do in about 5 days or so
i just want to noe
Old Jun 17, 2006 | 10:30 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
DIY LED interior conversion would run about $30.
Old Jun 17, 2006 | 10:32 AM
MaxBoost925's Avatar
Drug Money
TB restrictor mod and VIAS removal/fix.
you can do the catch can too.
Old Jun 17, 2006 | 10:43 AM
Good one, I did not think of that.
Old Jun 17, 2006 | 10:46 AM
ope2k4's Avatar
paint your calipers. Fog light rewire if you havent done it
Old Jun 17, 2006 | 12:08 PM
NeverBepeace's Avatar
How do you rewire your fog lights? What does rewiring do?
Old Jun 17, 2006 | 02:48 PM
14psisupra's Avatar
turns the fog lights on with the parking lights
Old Jun 17, 2006 | 05:24 PM
JiggaD369's Avatar
Any links for the write-up of the TB resitriction and VIAS mod?
EDIT: What are the benefits of these two? Sorry just got my 02 SE and want to do some *SAFE* mods lol.
Old Jun 17, 2006 | 05:30 PM
super6's Avatar
to remove the plate, just take off the intake, and TB, behind it ull find the plate, just remove and reassemble. people say ull gain 1HP or so, and about an extra mm of space for air.
Old Jun 17, 2006 | 05:52 PM
steven88's Avatar
Need A Light?
if i recall correctly, didn't removing your vias take a long time? i dunno if we should consider that a quick mod?
Old Jun 17, 2006 | 06:06 PM
Maximized2000's Avatar
AE Headlight mod. The best part...its free.
Old Jun 17, 2006 | 06:55 PM
FriscoMaxima's Avatar
how about some $8.99 ebay coilovers, blue blinkers, blinking valve stem caps, led windshield spray nozzles, and a HUGE spoiler?
Old Jun 17, 2006 | 07:37 PM
Gapp's Avatar
+1 ^^ can't beat the primered 6" crown moulding body kit either!
Old Jun 17, 2006 | 10:15 PM
JiggaD369's Avatar
The VIAS fix is only for 2000-2001 only correct? not for 2002?
Old Jun 17, 2006 | 10:57 PM
Drug Money
right.
removing/fixing VIAS takes a LONG azz time because the screws ALWAYS strip. I had to take off the plenum to get to the dam screw.
Old Jun 25, 2006 | 07:59 AM
mandymax's Avatar
get an "easy out" and it takes just ten minuits to get it off.It is a socket made to take off stripped bolts and you just turn it on and it grabs right away.costs about $10 for a whole kit at your local auto store.
Old Jun 25, 2006 | 10:26 AM
Drug Money
its not a bolt though, its a screw.
Old Jun 28, 2006 | 04:24 PM
ToneBoat923's Avatar
i want to replace the bumper lenses witht eh clear ones is that an easy fix? also im thinking of hd headlights...now can i change the bulbs (and is it easy to do?) or do I have to replace the whoel housing...i also want to clean the inside of the lense on my headlights...is there a way to do so?
Old Jun 28, 2006 | 04:27 PM
NmexMAX's Avatar
dot dot dot ...
is this Try reading the stickys all you need to know is in there
Old Jun 28, 2006 | 05:02 PM
shift_2kmaxima's Avatar
he's got 2k2 maxima......
but do a GAB mod....its free and good
good luck man
huso
Old Jun 28, 2006 | 07:41 PM
JiggaD369's Avatar
is GAB a mod that makes a noticeable improvement?
Old Jun 28, 2006 | 11:40 PM
spdfreak's Avatar
Yes, Like 400 WHP; no...alittle more, nothing much (I think it ads some noise).
Old Jun 28, 2006 | 11:50 PM
Drug Money
... it gives you more high end power while retaining your stock low-end torque.
Old Jun 29, 2006 | 04:51 AM
i felt a difference when i got it done (but that could've been because, i had my timming advanced at the same time)
btw: you should also advance your timing, you'll def. feel that man
huso
Old Jun 29, 2006 | 06:55 AM
BNotar35's Avatar
Is there any mods, quick or not, that would improve gas milage? and performace?
Old Jun 29, 2006 | 11:41 AM
AceofSpds's Avatar
wat
Nope
Have you not read any other threads on this forum???
Old Jun 29, 2006 | 09:19 PM
BNotar35's Avatar
apparently I didn't read it thoroughly..I'm just thinkin of stuff I could do to my Max. Thought I'd toss it out there.
JakeOfAllTrades
Oct 5, 2015 10:40 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
