Changing Drive Belts
Old Jun 21, 2006 | 08:14 PM
RabStyle's Avatar
I need to change both of them, I searched the board and I wasn't successful, so here is my question. What level of difficulty are we talking about? Anyone have a DIY walkthrough of the operation. I am mostly concerned about the tension on the belts. Is that something to be overly worried about? Thanks for your input and answers!
-Rob
Old Jun 21, 2006 | 08:17 PM
xlcrew's Avatar
I’m Back
it's only a little tough, the main one that drives the ac and alternator is very easy, the power steering is not so easy. i would say look up for a FSM and download it.
http://jime.homeip.net/tech.html
go here to find it. this is the best tool for your car
Old Jun 21, 2006 | 08:23 PM
RabStyle's Avatar
I have the FSM, it doesn't have a section on a step by step, only how to check them for wear
n/m I kinda found the solution
Old Jun 21, 2006 | 08:29 PM
RabStyle's Avatar
What about the deflection/tension part, how do I test for those?
Old Jun 21, 2006 | 08:45 PM
NmexMAX's Avatar
dot dot dot ...
Get a Haynes manual, it will tell you all you need to know.
Old Jun 21, 2006 | 08:55 PM
RabStyle's Avatar
Got a download link?
Old Jun 21, 2006 | 08:59 PM
NmexMAX's Avatar
dot dot dot ...
No, but I have a hardcopy.
Old Jun 22, 2006 | 08:03 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
This will give you an idea on HOW TO.... good luck
http://www.motorvate.ca/mvp.php/500
Old Jun 26, 2006 | 09:34 PM
RabStyle's Avatar
thanks, helps me see what I need to look for more so than the FSM
Old Jun 26, 2006 | 09:43 PM
RabStyle's Avatar
on the tensioner counter clockwise tightens and clockwise loosens correct?
Old Jun 26, 2006 | 10:12 PM
NmexMAX's Avatar
dot dot dot ...
If you're referring to the A/C/ALT---------> ..................
Make sure you loosen the pulley nut.
Old Jun 27, 2006 | 05:20 PM
RabStyle's Avatar
but it does apply to the power steering tensioner correct?
tsi6001
Oct 3, 2022 10:23 PM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
