Great... now I have the grey-black smoke.
Old Jun 20, 2001 | 04:43 PM
punkdork's Avatar
Hey guys. My car's doing it now. I started it up today and poof big cloud of grey/black smoke. It also runs very rich on startup. I know all maxes run rich, but if we idle in the garage for any period of time (with the door fully open) the car fills with rich exhaust smell. Perhaps a problem with ignition coils? The puff of smoke seemed awfully large for a car with only 20k miles on it.
Old Jun 20, 2001 | 04:56 PM
UMD_MaxSE's Avatar
Got Bent?
hmmmm.....it could be the coils, but is your car pinging at all? Check the plugs and see what condition they are in. That may give you some more info.......good luck
Old Jun 20, 2001 | 05:07 PM
punkdork's Avatar
Well... it pinged when I had the Pop Charger on... :/
I'll have to take a look at the plugs. Damn... I gotta get a spark plug socket now. hehe
Old Jun 20, 2001 | 05:12 PM
Max_Vader_2K's Avatar
I got it too!
Let me know if you find a fix to this problem. I'm still looking.
Old Jun 20, 2001 | 05:21 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Irvine78's and my sparkplugs were sort of white (lean) when we took ours out. I'm pretty sure yours will be white also.
Old Jun 20, 2001 | 05:22 PM
punkdork's Avatar
There was a big @ss cloud... it nearly killed my GF. It was large enough to be comical.
Old Jun 20, 2001 | 05:29 PM
Y2KevSE's Avatar
Hmmmmm...... that doesn't sound right. Dealer?
Old Jun 20, 2001 | 05:34 PM
punkdork's Avatar
Re: .
I bet they'll be looking at intake. I think I'll remove my oscai tube and put the paper filter back in.
My only other thought is my tank is really low right now. Perhaps a lot of fumes are causing this?
I gotta go in for an oilchange soon so if it doesn't clear up after a fill up then I'll mention that. Plus my stupid AC fan is ticking.
Old Jun 20, 2001 | 05:55 PM
UMD_MaxSE's Avatar
Got Bent?
bad tank of gas?
Old Jun 20, 2001 | 05:57 PM
punkdork's Avatar
bad tank of gas?
I normally fill up with Texaco... they're supposed to be good. Right? 3 different stations too.
Old Jun 20, 2001 | 06:04 PM
UMD_MaxSE's Avatar
Got Bent?
I think Texaco gas is fine as far as I know. I stick to Chevron, but either way it should not make a huge difference as long as it is not a really cheap/crappy brand.
Old Jun 20, 2001 | 06:10 PM
Y2KevSE's Avatar
You should take the car in if it's been happening for a while already.
Old Jun 21, 2001 | 07:35 AM
maxse01's Avatar
I would defenitly reccomend going to the dealer if the cloud of smoke is that big. I don't think it could be the spark plugs cause they say the stock platinum plugs are good for 100,000 miles. Not that i would ever wait that long. What do you guys suggest the spark plug change interval to be? 30k 40k? Thanks
Old Jun 21, 2001 | 07:42 AM
UMD_MaxSE's Avatar
Got Bent?
It's not that the plugs are bad, but you can examine them to see what's wrong with the engine by looking at their color. I would change the stock plugs probably around 50 or 60k miles....
Old Jun 21, 2001 | 07:49 AM
yongjun's Avatar
Check the plugs if not.
go beat nissan's head
100k miles my ***
Old Jun 21, 2001 | 08:02 AM
maxse01's Avatar
Thanks UMD.... You think it's worth getting those Platinum +4 spark plugs. They are supposed to give a little power and once i incorperate the Twin Spark thing it should make some hp. you think? Thanks
Old Jun 21, 2001 | 08:10 AM
UMD_MaxSE's Avatar
Got Bent?
I would stick with the OEM NGK's.......
Old Jun 21, 2001 | 08:47 AM
Alexis's Avatar
I have heard good things about the Denso Iridium plugs. Some have shown dyno sheets claiming pretty significant improvements in power. This is what the Lexus GS400 uses I think.
http://www.densoiridium.com/
The accord v6 guys like it, and their engine isn't tuned very aggressively (it only needs 87 octane)
http://superhonda.org/board/showthre...=denso+iridium
this is the dyno claiming a power improvement. It is just one sample, but who knows...
http://www.autocarparts.com/images/p...o_AccordV6.gif
Old Jun 21, 2001 | 09:30 AM
maxse01's Avatar
Thanks. Alexis, i went to that page and those iridium plugs look pretty hot. I may give them a try and see how they work.
Old Jun 21, 2001 | 10:54 AM
UMD_MaxSE's Avatar
Got Bent?
Originally posted by Alexis
I have heard good things about the Denso Iridium plugs. Some have shown dyno sheets claiming pretty significant improvements in power.....
thanks for the info.....
Old Jun 21, 2001 | 12:19 PM
mike-777's Avatar
Just curious, are you one of the guys who regularly races and runs the engine to red line?
A warmed up Ferrari can do this all day long as they are designed to be run hard.
The Max on the other hand is still a "family" car. I doubt the designers intended red line to be hit on a daily basis.
jerrod99_se-l
Aug 27, 2015 08:27 PM
FlaMark
Aug 21, 2015 11:06 AM
acw
Aug 13, 2015 12:50 AM
josh_arby
Jul 16, 2002 08:23 AM
