Funny Feeling in steering
Old Jun 27, 2006 | 04:18 PM
Sari's Avatar
When making a sharp turn (onramp/offramp to a freeway) there is a lot of force in the steering fighting against me. Any ideas what would cause this? It's almost as if when I want to turn right, the car wants to stay straight and fights me turning it. It's an 02 SE 6 speed. Any ideas would be greatly appreciated!
Thanks!
Old Jun 27, 2006 | 08:15 PM
djfrestyl's Avatar
Suspension Yoda
My first guess is your power steering belt is loose/slipping. When was the last time they were changed?
Old Jun 28, 2006 | 04:36 AM
Sari's Avatar
I have to assume it's orignal. I've just had the car a few months. I hope you're right cause that's simple enough.
Old Jun 28, 2006 | 07:06 AM
MerlotMax's Avatar
Could it be your not used to the torque steer yet? Power + FWD = torque steer.
Old Jun 28, 2006 | 08:20 AM
Sari's Avatar
No it's not torque steer. It happenes even when the vehicle is coasting. Is there a certain type of fluid you guys would recommend for the steering? I'm thinkin I might change it since I have no way of knowing how old it is and see if that helps (along with the belt).
Old Jun 28, 2006 | 11:37 AM
Swiyzee's Avatar
Maxipimp
Mine has been doing that since I got it. I thought it was supposed to be that way. Isn't that like speed sensitive steering or something like that?
Old Jun 28, 2006 | 02:28 PM
trigger005's Avatar
dont think so
at least no so much that your feel its 'fightin against u'
u guys should check the fluids section and try changing ur power steering fluid
Old Jun 28, 2006 | 07:31 PM
rapidsft's Avatar
I'm pretty sure what you are experiencing is normal. I've driven many other cars and the Maxima has a very firm steering radius. If it's too strong then the 1st thing i would do it take the car to an alignment shop and make sure that there is not problems with the toe. I doubt it's a problem, but having your alignment done every year or so is a real good idea, because if there is a problem it could easily be identified.
Fbana41
Aug 29, 2016 12:18 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
ToTheMax305
Sep 23, 2015 09:11 PM
JoshG
51
Sep 21, 2015 10:41 PM
