Non working windows and door locks Need Help
Old Jul 18, 2006 | 04:23 PM
SaVas's Avatar
Today on my way home from work, I went to put up my drivers window, and it would not go up. The buttons would not do anything. None of the window switches on any of the doors will work, for windows or even the door lock switch.
I replaced the relay for central locks under the hood thinking that was it, but to no avail.
I can turn on the alarm, but it will not lock the locks. When I turn the alarm off the locks stay locked.
Anyone have this issue before? Its supposed to rain tonight and I live in the city, so no garage.
Thanks in advance.
Old Jul 18, 2006 | 06:12 PM
illlojik's Avatar
I C U
Take off the door panel and check to see if the harness or any individual wires got disconnected.
Old Jul 18, 2006 | 06:36 PM
spdfreak's Avatar
Fuse...The manufacture usually puts a couple of circuits on each fuse, so it doesn't sound like the problem, but it's a good place to start.
Old Jul 18, 2006 | 08:03 PM
BewstAdd1ct's Avatar
yep, id check all the fuses also.
EDIT: fuses 1, 10, 13
Old Jul 19, 2006 | 07:11 AM
maseo77's Avatar
I have this exact same issue, and replacing the fuses does nothing for me either.
Thanks in advance.
Old Jul 19, 2006 | 09:27 AM
LoSt180's Avatar
You're main switch might have gone bad. If you can prove the trouble to that, I have an extra one I could sell you.
Old Jul 19, 2006 | 11:58 AM
maseo77's Avatar
If all the switches dont do anything, then replacing the main switch wont help at all. Nice offer though
Old Jul 20, 2006 | 08:15 AM
matimbo's Avatar
same problem
I have the same problem also, my seat does not work. I have taken it to a mechanic and he gets it working and says its fixed and as soon as I get on the road, I try to roll the window down, or move my seat back and nothing. He has replaced the relay and it worked in his lot of course, but about 5 minutes away from the shop it stopped working again.
Old Jul 21, 2006 | 11:38 AM
terra's Avatar
I have the same problem, can someone PLS help!! This is probl. is a MOTHER()#&$(&!!!
Old Jul 21, 2006 | 02:35 PM
03Max3.5's Avatar
yea that happend to me one time. it was a hot summer day and i went to put the window up to turn on the ac. and everytime i hit it to go up automatically it would go up and then open up again. i was like what the hell is going on. i did it twice but then on the second try it went back to normal, and i havent had problems. since.
Old Jul 24, 2006 | 05:20 AM
terra's Avatar
Well fellas, I figured out a quick fix to the problem without spending any money...With the help of illlojik, he emailed me the electrical system breakdown, and from there I just went to the "main driver door switch", matched up the wire colors, tapped into them and ran 2 wires from the corresponding window, straight to the batterys' "-" & "+" side. They let right up, BUT, i still can't get the driver side window to go up, for some reason it didn't work for me when I tried that one. Still haven't figured out the cause of the problem yet, but thats work in the making!! If anyone needs this electrical layout let me know...
Old Jul 24, 2006 | 06:14 AM
illlojik's Avatar
I C U
No problem...Thanks for the shout out. Hope you get that fixed soon. I'm still trying to figure out why my passenger side window will go down but only go up sometimes or never when using the passenger side switch, but it's fine when using the master switch(drivers side switch.)
Old Jul 24, 2006 | 07:45 AM
terra's Avatar
Hmm, sounds like a motor problem, or your switch has a short, I say motor because when they "get ready" to go out, they work half assed!!!
Old Jul 24, 2006 | 11:09 AM
terra's Avatar
ok fellas, I've got ALL the windows up now, here's a description of the wire colors, just go into the main switch on the driver side door:
LF Window- Blue & Green
RF Window- Red/White & Red/Black
LR Window- Yellow & Red
RR Window- Green/White & Green
Just tap into these wire and run it straight to your battery, depending on what you want the window to do (*go up or down*) depends on which wire you hook to the positive side of the battey....Have fun, IT'S VERY SIMPLE!!!
Old Jul 24, 2006 | 12:08 PM
if youve got proper power to the switch, then you can just jump to the power and ground of the switch itself to activate a window (and bypass the switch), rather than run wires to the battery
Old Jul 24, 2006 | 12:20 PM
terra's Avatar
How true, and now that you said that, I'm like, "why the hell didn't I do that"...hhahaa!! Good one bro, now why didn't you suggest like LAST FRIDAY!! haha!
Old Jun 25, 2007 | 08:47 PM
wyskibumm's Avatar
Same problem on hot day
It seems that when the car get hot from the sun, especially direct exposure to the sun, the driver's side window doesn't want to roll down. Its a son of a gun, cause it will work when the temp cools off, but then tonight same thing and when it cooled off, nothing still. All 3 others work properly and when i push the button i just hear clicking. Gunna take apart the door this weekend and get in there. Is there any airbags or crap in there??
Old Jun 25, 2007 | 09:10 PM
maseo77's Avatar
Same deal with my 00max, except ALL my windows act up.
King_Ten_Ahead
Sep 30, 2015 04:27 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
kenc15
Aug 5, 2015 08:29 AM
