Ses..........
Old Jul 22, 2006 | 08:39 AM
dfownz's Avatar
Ses..........
I have a 00 SE 5spd and last night the SES light came on.
Today I went down to my work and checked it out with the scanner: Manufacturer ignition system or misfire. I had this same code twice, which I assume means I've misfired twice. The scanner does not tell me which cylinder it is so I can't even replace that coil to see if it stops.
What would you guys do?
Thanks,
DF
Old Jul 22, 2006 | 09:15 AM
bigfatty's Avatar
Booyah grandma.... BOOYAH
What was the exact code you got?
Old Jul 22, 2006 | 10:56 AM
dfownz's Avatar
I can't remember the P0#### but it was manufacturer ignition system or misfire.
Old Jul 22, 2006 | 11:00 AM
MaxPaul's Avatar
man i just had the same thing in a 2000 max se 5 spd as well... turns out mine was coil and cylinder 6..get a better scanner tool taht might help you out..can even be something stupid like the plugs..
Old Jul 23, 2006 | 07:48 AM
dfownz's Avatar
I put in Iridium plugs not more than 10k ago so I'm sure that they are fine. Where did you find that scanner? My work (autozone) only has the crappy one for free use. I don't want to have to pay 150 just to have them tell me what cylinder is misfiring.
DF
Old Jul 23, 2006 | 12:45 PM
BewstAdd1ct's Avatar
get the code number, either itll tell you which cylinder it is, or itll be a p0300
