Failed Smog (high NOx)
Old Aug 3, 2006 | 10:24 AM
roastduck88's Avatar
I just took a smog test in CA and I failed it because of high NoX, any ideas how i can solve it? I have a stock CAT, after market exhaust, spark plugs were changed recently.
Old Aug 3, 2006 | 10:30 AM
upstatemax's Avatar
Make sure your EGR is working properly.
Old Aug 3, 2006 | 10:59 AM
Thanks!
Yup EGR is working fine.
Old Aug 3, 2006 | 11:10 AM
upstatemax's Avatar
Originally Posted by roastduck88
Thanks!
Besides a CEL it might not open or close all the way thanks to the crud that builds up on the valve. If the EGR is not fully open you can fail a Nox test easy, especially in the recent heat.
Old Aug 3, 2006 | 02:59 PM
carsarecool's Avatar
They actually do the sniffer test in CA?!
Old Aug 3, 2006 | 03:42 PM
frankd121's Avatar
I believe you can determine abnormally high amounts of NOx through the OBD system.
NOx is created because of high (or excessive) combustion temperatures. You should scan for any codes; this might help you determine your exact problem.
Old Aug 3, 2006 | 03:59 PM
Just scanned for codes, no codes either. Yeah.. CA takes readings at 15mph and thne at 25 mph.. those bassards!
Old Aug 3, 2006 | 06:53 PM
5thgenmaxima's Avatar
+1 for what keeps being said. IIRC around 2500 + degrees fahrenheight.
Almost always EGR related, unless you have other engine issue. (misfire, lean condition, preignition, etc.)
First thing I would do is double check and make sure your egr system is working.
Old Aug 4, 2006 | 07:18 AM
Thanks! I'll give it a shot.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
