Having Trouble Removing Rotor From Car!!!!
Old Aug 12, 2006 | 10:26 AM
NeverBepeace's Avatar
I removed the caliper, break pads, and shims. But I cannot get the rotor off. its suppose to come right off? Im having trouple getting it off. Any suggestions on how to take this off? I have an 01 max se.
Old Aug 12, 2006 | 10:41 AM
vipergtsr6's Avatar
In the past while i was working on brakes, I have found that if the rotor won't come off, you can bang on it with a rubber mallet. Not hard enough to break it, but hard enough to knock it loose. I am not suggesting that you try to hit the rotor from teh back to knock it off, just bang on the face of the rotor a little. If that doesn't work then I don't know what to tell you.
Old Aug 12, 2006 | 11:02 AM
piotroosh's Avatar
Unless you're replacing rotors, and don't need the old one... ;-)
Old Aug 12, 2006 | 11:10 AM
Lolol i am replacing rotors. Just for that side.
Old Aug 12, 2006 | 11:20 AM
phenryiv1's Avatar
Mod her. Ate her.
Rubber mallet FTW
Old Aug 12, 2006 | 11:28 AM
LA02MAX's Avatar
there's also a couple threaded holes on the back of the hub where you can thread a matching bolt through, which pushes the rotor out....try the rubber mallet first (worked for me) and if you still can't get it off, try threading a bolt throught those holes
Old Aug 12, 2006 | 11:38 AM
phenryiv1's Avatar
Mod her. Ate her.
That works, but noone can seem to remember the proper thread pattern/size/length.
I almost forgot- a brass mallet/hammer works well, also.
Old Aug 12, 2006 | 11:49 AM
nexus_7's Avatar
These non rust people have no idea how bad it can be for us. YOu will jsut need to beat on it with a hammer, I end up using a sledge. spray behind, pound, and annoy neighbors.
those stupid screw threds just rip out because the rust.
Greg
Old Aug 12, 2006 | 12:39 PM
What kind of rotor should I get? I know pep boys have them for $24.99. Should I get those?
Old Aug 12, 2006 | 12:51 PM
nexus_7's Avatar
eithor of the group deals going on. Brembo is where it is at.
Greg
Old Aug 12, 2006 | 01:17 PM
phenryiv1's Avatar
Mod her. Ate her.
Greg
I live in the rust belt- just like you. That is why I said that a brass hammer might help. It absorbs a lot of the reverberation and normally has the mass/heft to break loose a rusty rotor.
Old Aug 12, 2006 | 01:19 PM
phenryiv1's Avatar
Mod her. Ate her.
I got brembo blanks from http://www.importrp.com/home.php and really like their customer service. Shipping was really expensive, though, so maybe price them out on the internet and see if somewhere local will price-match.
Brembos will last a long time if you keep your lugs properly torqued.
Old Aug 12, 2006 | 03:15 PM
opanick's Avatar
yea i got the brembo through importrp.com and everything worked out great, shippin was a tad bit expensive and took 2 days longer than i expected but all is well
Old Aug 12, 2006 | 04:50 PM
SilverMX's Avatar
I just used a hammer and would spin mine a little as i banged on them from behind...that way you dont put too much lateral stress on the wheel hub bolts. If you see rust dust coming out from the hub bolts...it's working..keep banging...but some muscle in it man.
Old Aug 12, 2006 | 05:50 PM
BEJAY1's Avatar
Conecarver
Here's my tips
http://forums.maxima.org/showthread.php?t=469787
Old Aug 13, 2006 | 07:13 AM
Well guys, i finally got it off today. I just used a hammer. hit it for a awhile........then it came out. Thanks for your suggestions.
Old Aug 14, 2006 | 10:35 AM
Epacy's Avatar
Unsuccesful STL Coordinator
Greg
Try having your hubrings heat-seize to the hub and trying to remove the whole tire/wheel assembly. I had to beat the living hell out of my front tires to get them off. On one of them, the hubring stayed on the hub and the other came off in the wheel. Was total bs!
I tossed the rings and haven't really noticed any more vibration. Not worth going through that again.
And yeah, the front rotors rust like mad as well.
Old Aug 15, 2006 | 07:22 PM
NisTech's Avatar
beat it with a hummer buddy just make sure you don't hit any studs
Old Aug 15, 2006 | 07:38 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Two posts up^^^
That's what he did and what about 90% of people in this thread suggested.
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
03VQMAX
Sep 25, 2015 04:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
RealityCheck
Aug 5, 2015 06:18 AM
