how much to replace rear brake caliper?
Old Aug 16, 2006 | 06:40 PM
mastah's Avatar
does anyone know how much it would cost to replace the rear brake calipers on a '02? or can i just get the piston fixed somehow? I believe mine are frozen cause I had a really hard time pushing them back when changing the pads.
Old Aug 16, 2006 | 06:49 PM
VaporHead
Did you remove the brake cylinder cap before trying to reset piston? Naturally piston will be difficult to push back in if cap is stilll on (due to pressure). Make sure you use a brake caliper piston tool when depressing piston or else risk damage to piston and caliper.
Old Aug 16, 2006 | 06:52 PM
AceofSpds's Avatar
wat
You know on most imports on the rear calipers you have to twist them to compress them right?
Old Aug 16, 2006 | 06:55 PM
VaporHead
Not sure about the rears, but front just depress in.
Old Aug 16, 2006 | 06:57 PM
AceofSpds's Avatar
wat
yup, on the rears you gotta turn em to get them to compress, and ive noticed ppl on here using hammers and stuff to get em to go in not knowing this and fawking up their calipers.
Old Aug 16, 2006 | 07:03 PM
VaporHead
Good info to know!
Old Aug 16, 2006 | 07:13 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
each should go for around $300 call DaveB.. autozone might have them cheaper.... or you can just buy the repair kit and do it yourself
Old Aug 16, 2006 | 07:18 PM
super6's Avatar
if they are indeed frozen, u rebuilt ones are about 100 each. or u can try a do it urself fix like this: http://bmwe32.masscom.net/sean750/ca...akeCaliper.htm
Old Aug 16, 2006 | 08:17 PM
mastah's Avatar
thanks for the replys. yes i know that they twist back in. it was just that when i tried to twist them back in it too a lot of force. so i believe that they are frozen and need to be fixed. i don't think i'll have the time to rebuild them myself. how much would the dealer charge for a rebuild?
Old Aug 17, 2006 | 07:40 AM
dank104's Avatar
I didn't even think about this...now it makes sense. The last time I replaced my pads, it took me about 30 minutes to turn and compress each rear caliper piston. I know they were not seized so I was wondering why it was taking so long!
Old Aug 17, 2006 | 11:30 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Nissan charges $350 for a rear caliper for the 2002-2003. (I had both replaced)
Old Aug 17, 2006 | 11:45 AM
kvk2003max's Avatar
I replaced the rear driver side caliper recently. Got the caliper for $65 from Autozone + $62 core charge.
Old Aug 17, 2006 | 02:34 PM
mastah's Avatar
hey SEmy2K2go. can you recomend me to a good nissan dealer in columbus? I'm going to be starting grad school in sept at OSU and need to find a good dealer to get my services done. thanks. and $350 per caliper is a lot... i hope i don't have to replace mine.
Old Aug 17, 2006 | 02:43 PM
LA02MAX's Avatar
Tim, do you know why they charge so much for the rears? My front 6th gen calipers were only $60...
But yes, you do have to twist the piston to compress it...either use a pair of pliers very carefully or go to autozone and rent a piston compressor...
Old Aug 17, 2006 | 03:06 PM
NmexMAX's Avatar
dot dot dot ...
Buy one for 8$.. Piston compressor . I thought it was more like a ratched adapter.
Old Aug 17, 2006 | 03:16 PM
LA02MAX's Avatar
hmm, the one i rented was a brake caliper piston compressor, and it had a clamp type thing with different size adapters that had two pegs that went on a disk that rotated the piston while compressing it...
like this:
Old Aug 17, 2006 | 04:26 PM
super6's Avatar
u can just use a pair of pliers and C clamp
Old Aug 17, 2006 | 04:30 PM
NmexMAX's Avatar
dot dot dot ...
Why use that to compress it when the other tool is much simpler and cheaper I'd imagine... If all you need to do is compress it..
Make sure and line up taht nudge behind the brake pad also.
No you cannot use a c-clamp for the rears...
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
