ES sway-bar bushings install *PICS
Old Aug 20, 2006 | 08:28 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I know this mod is slightly common, but I thought I would throw this thread in for searching reference. A certain inclusive page.
Autozone now sells ES bushings at a very competitive price, $19.99. I was surprised to see them sell them, but it seemed they only stock the bushings for the aftermarket sway-bar. I had to order the bushings, but it only took 2 days to come in.
Install was really simple. This of course, after the weekend before I pulled my heat-seized hub rings off the front wheels with much hammering.
Pre-removal.
Finished product.
Shot from the front of the car.
Reaction.
The Max is very straight through turns. Well-balanced and handles true. A definte upgrade I would recommend. For the price, you cannot beat it. Plus, the fact you can get it locally is great.
Here is the write-up, if you need it. It is very straight forward.
Front Sway Bar How-to
Old Aug 20, 2006 | 08:43 PM
ctrent86's Avatar
Good write up and info
Old Aug 21, 2006 | 07:39 AM
zero2sixtyZ's Avatar
You embarrass me.
Thanks, definitely want to do this after installing my shifter bushings and seeing how much of a difference those made!
Old Aug 21, 2006 | 08:05 AM
boondoxmax's Avatar
I want some. When I had mine replaced under warranty the car felt so tight and responsive. The OEM are terrible and are the cause of front end noise most max owner have dealt with.
Old Aug 21, 2006 | 08:06 AM
Ephraim's Avatar
sweet, so is this part of Autozone's new marketing thing where they are stocking more aftermarket parts? how did you find out Autozone had them?
Old Aug 21, 2006 | 08:55 AM
Epacy's Avatar
Not sure about the marketing bit, but I jst saw them while I was in there one time. The stock end-link bushings as well.
Old Aug 21, 2006 | 07:37 PM
Epacy's Avatar
Well, I didn't provide the how-to, that was Polo, it is more of a reference. The job is pretty easy to figure out on your own.
Old Aug 22, 2006 | 01:44 PM
vsamoylov
lets see how well they hold up
Old Aug 22, 2006 | 02:05 PM
SHOman's Avatar
Nice work on the write up.
Cheap good mod. Next on my list.
Thank you!
Old Aug 22, 2006 | 02:50 PM
Ride2kMax's Avatar
great this is what i was looking for
thanks
Old Aug 22, 2006 | 03:35 PM
MAXRB8's Avatar
Excellent writeup! With really good corresponding pics! Do the 14mm bolts need to be torqued? And if so to what spec?
Old Aug 22, 2006 | 05:56 PM
03on18s's Avatar
i'll be installing these along with control arm bushings and subframe bushings all from ES in the next couple weeks. I ordered the bushings, but ES said they have to custom make them and I will get them within 2 weeks. This will help with at least one install.
Can you give me some perspective on where those pics were taken from? I've having a hard time placing the pictures. Thanks!
Old Aug 22, 2006 | 06:00 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I'll follow this soon.. Great write up Epacy....
Old Aug 22, 2006 | 09:37 PM
808MAX-SPEC's Avatar
I'll put this on my to-do-list. Excellent write up!
Old Aug 23, 2006 | 05:26 AM
Ride2kMax's Avatar
Yesterday i went to autozone and order mine but i used your part number to order them and then i remember noticing that you have a SE which I am not sure if they fit my GXE so i took a second trip and order a different set for a GXE/GLE .
One i will return when it gets there i just want it to see the difference and make sure that i was getting the right one.
Will The SE bushings fit the gxe?
Anyone wants to collaborate.
Old Aug 23, 2006 | 11:14 AM
Duckman540i's Avatar
VE Powah!!!
Pics aren't working for me?
Old Aug 23, 2006 | 11:37 AM
MacGarnicle's Avatar
me neither.. I want to see this
Old Aug 24, 2006 | 05:07 AM
Ride2kMax's Avatar
Old Aug 24, 2006 | 09:00 AM
yvfed1's Avatar
Greetings!
My '02 6sp has developed noises from the front end
Since I installed Stage 2 LTB about a year ago, I thought perhaps the transverse link bushings are shut (althought I followed Matt Blehm' instructions to the letter). I lifted the car but could not see a fault with thouse bushings.
So, after reading this post I started thinking - perhaps these swat bar bushings went bad, not the transverse link?
Could you guys tell if:
- is there a way to verify if sway bar bushings are shut?
- are we refering to the stock sway bar?
- what are the symptoms to look for? Currently the car makes clicking noises when turning, and not to tracking well - meaning a constant steering input changes are required to keep it straight.
- what is the Autozone part(s) numbers or perhaps other vendor sells them?
Thanks in advance,
Eugene
Old Aug 24, 2006 | 12:18 PM
Ride2kMax's Avatar
sway bar bushings Part ## 75125R
Old Aug 24, 2006 | 12:41 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
last i remember, the se has a thicker sway bar by 1mm so the bushing would be too big for your sway bar.
Old Aug 24, 2006 | 12:51 PM
2kSC's Avatar
From ES website:
Maxima
Front Sway Bar Frame Bushings
22mm
7.5124
23mm
7.5125
what do they list two sizes for our cars?
Old Aug 24, 2006 | 01:07 PM
kcowden's Avatar
Originally Posted by 2kSC
From ES website:
Maxima
22mm
7.5124
23mm
7.5125
See previous post from sloppymax....
Old Aug 24, 2006 | 04:14 PM
yvfed1's Avatar
Thank you guys! Any advice as what kind of noises should be looking for or verify the bushings are shut?
Thanks,
Eugene
Old Aug 30, 2006 | 11:02 AM
FriscoMaxima's Avatar
it is not bushings, it's the sway bar links that go bad...
Old Aug 30, 2006 | 03:43 PM
boondoxmax's Avatar
Correct but they are bushings. You can call the end links also, but when you look up the part its' called end link bushings....
Old Aug 30, 2006 | 03:51 PM
Epacy's Avatar
Alright everyone, pics are back up. Sorry, was in Maine for the last week and had to shut down the web.
The instructions that came with the bushings say to torque to spec. I meant to check the spec before I removed them, but did not. I just made mine good and tight, but didn't over-do it.
Most pics were taken from the wheel, except for the one from the top of the engine bay.
The size issue has been answered. 23mm only for SE.
I haven't driven the car enough to notice any decrease in front end noise.I can tell it takes corners much flatter. If you look at Polo's write-up, you will see his bushings are much more worn. You can see the rubber doesn't touch the sway bar all around.
Old Aug 30, 2006 | 04:59 PM
yvfed1's Avatar
The manual specifies torques as 37-43 ft-lb.
E
Old Aug 30, 2006 | 05:08 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Awesome write-up, dude. Is there really a big difference or is it only subtle?
Old Aug 31, 2006 | 11:47 AM
bladerunr's Avatar
Does ES make the end link bushings also?
Old Aug 31, 2006 | 12:24 PM
Did you have to drop your cross member and undercarriage for that process?
Old Aug 31, 2006 | 12:32 PM
PoLo's Avatar
2-Wheelin it...
no. as per my writeup, you only need to remove the wheel.
to be honest, i've provided enough detail in the write-up that you shouldn't have ANY questions.
please refer to it again: http://www.digitalpolo.com/2002Maxim.../FrontSwayBar/
Old Aug 31, 2006 | 01:05 PM
well, sorry for asking!!!
Old Aug 31, 2006 | 01:22 PM
DrKlop's Avatar
Driving is the next best thing
subtle...
but it's there!
Old Sep 1, 2006 | 03:45 AM
Epacy's Avatar
Well you have asked, and been answered. The write-up is pretty clear.
Old Apr 13, 2008 | 11:55 AM
hi-tek22's Avatar
HEY EPACY WOULD YOU HAPPEN to still have the write up anywhere?
or in a word document or PDF or maybe you found a different host
thanks!
Old Apr 13, 2008 | 12:07 PM
PoLo's Avatar
2-Wheelin it...
thanks!
it should work now. my site had crashed, so i lost everything. had to rebuild it...just uploaded it for you.
Old Apr 13, 2008 | 04:23 PM
Armon's Avatar
sweet. nice write up.
Old Apr 13, 2008 | 06:26 PM
blkAEmax82's Avatar
Glory Glory Man United
thanks to whoever bumped this .. Good write up, its a project that needs to be done soon .
Old Apr 13, 2008 | 07:59 PM
wyche89's Avatar
wait, so what exactly do these sway bar bushings do? and do you need an aftermarket front sway bar to do this, or can you put the bushings on a stock front sway bar?
