power seat stopped working
Old Aug 30, 2006 | 02:44 PM
KCMC582's Avatar
i noticed it first when i got in, started the car, and the seat didnt move into position. i shut it off, turned it on again, nothing. the right side slides about a half inch, and then stops. the left side doesnt move at all, like its snagged on something. i reached under there, nothing stuck or anything that i could feel. i gotta call nissan tomorrow, at least the seat isnt too close. at least i got a warranty, i just didnt want to have to bring the car to the dealer AGAIN.
the weird thing is, just before i noticed it didnt move, my Viper remote shut itself off or something and rebooted...weird and coincidental.
Old Aug 30, 2006 | 11:57 PM
maxrailfan1's Avatar
Sometimes I have the same problem. Every couple of months, my driver's side seat won't move forward or backwards. I let it sit overnight, start the car in the morning and then it works fine for several months. I would like to find out whats wrong also.
Old Aug 31, 2006 | 05:19 AM
KCMC582's Avatar
i was hoping that would work, but no. I think i am going to remove the fuse that controls them and reinsert it, hopefully that will do something, but im not optimistic about it. I cant get a loaner car at nissan til 9/12.
Old Aug 31, 2006 | 07:47 AM
9DTALON's Avatar
The brushes in the motors get dirty and stop making good contact. You can remove them (taking the seat out) and clean the brushes w/sandpaper. My inlaws have a Pathfinder that was doing the same thing. I did this and it works perfect now. To get it working temporarily try whacking the motor with a hammer while on the car, 9 times out of 10 it will start working again. BTW: the dealer is going to replace the whole 900$ adjuster assy.
Old Aug 31, 2006 | 08:29 AM
KCMC582's Avatar
i could try that, thanks, but its more or less worth my $50 deductible to just have them replace it under warranty, since im not really in the best position and location to do work myself.
at least its back and i can still drive comfortably, if it was too far forward id be smacking the hell out of it.
Old Aug 31, 2006 | 04:14 PM
CKOTuHA's Avatar
I have the same thing. My right side moves an inch up or down but the left side is like glued. Maybe I should try smaking it too.
Old Aug 31, 2006 | 06:32 PM
embraer's Avatar
This is a known issue for this gen Maxima/I30/I35. Basically your motor is going and needs to be replaced. There is a TSB out on this that walks you through taking the seat out and replacing the motor.
I have this same problem and have gotten to the point where the seat does not work at all anymore.
http://www.infinitihelp.com/Ownershi.../ITB00-067.htm
Old Aug 31, 2006 | 06:58 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
don't use a hammer..use a screwdriver and hit it a few times.. it will come bac to life
Old Sep 1, 2006 | 03:41 AM
nicks79's Avatar
check the wiring harness for cracks and shorts. I had the same thing on my, wiring harness was rubbing against metal fram of the seat, would short out without blowing the fuse.. YOu will have to take seat off, since you can see it from under when the seat is attached
Old Sep 1, 2006 | 03:36 PM
NisTech's Avatar
that bulletin wiull fix it. If you still have warranty it will get fixed for free. We actually stock it.
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
kenc15
Aug 5, 2015 08:29 AM
