Are the 6th gen rotors worth it?
Old Sep 3, 2006 | 08:07 PM
Gjohnson's Avatar
I think my rotors may be a slightly warped, so I'm considering picking up Matt's kit for the 6th gen rotors. But for those who have purchased the kit, do you feel it is worth the extra $150 for the brackets? I know Matt's a stand up guy (when he lived in Tulsa, I stopped by his house and he replaced the bushing on my old 3rd gen) I'm just wondering if you feel a real difference in braking, considering your still using the stock caliper?
Also, does anyone know if these same brackets will work if I upgrade to 300zx brakes later down the road?
Old Sep 3, 2006 | 08:22 PM
irish44j's Avatar
retired moderator
yeah, I thought it was worth it - though frankly it's MORE worth it to get the 6th gen rotors + 6th gen calipers...then you don't need brackets, it bolts right up. The calipers can be found used for about the price of the brackets anyhow and the 6g calipers have alot more power and pad area (and look nicer) if you're not worried about the extra unsprung weight
I'm not sure if the brackets are the same - I sold by OEM caliper/6g rotor brackets before getting the 300zx brackets. They do look similar, but might have a different offset....
Old Sep 3, 2006 | 08:35 PM
Gjohnson's Avatar
Hmmm... I never thought about getting the 6th gen calipers, but I assume they are still lacking compared to the 300zx brakes right? Oh, and will they fit under the 5.5 gen stock wheels?
Old Sep 3, 2006 | 09:05 PM
vsamoylov
get the 6th gen calipers and rotors. the only downside is the weight.
Old Sep 4, 2006 | 07:04 AM
Gjohnson's Avatar
I just looked around on Autozone.com and it looks like the 6th gen calipers would be cheaper then getting the brackets and using the 5th gen clipers. Hmmmm........ sounds good to me.
But will they fit under my wheels or will I have clearance issues. My Max came with 5.5 gen stockers.
Old Sep 4, 2006 | 07:24 AM
kobalt's Avatar
You need 17" wheels
Old Sep 4, 2006 | 07:39 AM
Gjohnson's Avatar
I have 17" wheels. I have the 2002-2003 stock 17" wheels.
But I did some searching and found a thread that Irish had on installing this kit. I'm pretty sure he said they wouldn't clear my 5.5 gen stock 17's.
Can anyone confirm this?
Old Sep 4, 2006 | 08:50 AM
MaxedOut's Avatar
they wont clear 5th gen (2000-2001) but they will BARELY fit 5.5th gen(2002-2003) they will have like a nickel clearence between the caliper and the rim..
Old Sep 4, 2006 | 11:19 AM
irish44j's Avatar
retired moderator
They will clear YOUR SE 17's, just not the 00-01, which are a bit different. Even with yours the clearance is tight and I would suggest maybe some 5mm spacers...
Old Sep 4, 2006 | 01:03 PM
LA02MAX's Avatar
http://forums.maxima.org/showthread.php?t=478631
they fit like a glove.
Old Sep 4, 2006 | 01:59 PM
Gjohnson's Avatar
Hmmm.... Well, does anyone know if the 28mm 300zx brakes will clear these same rims. I just found out my buddy has a set laying around.
Old Sep 4, 2006 | 02:02 PM
irish44j's Avatar
retired moderator
no, they won't even come close, even with spacers. You need at minimum a 35mm offset on the wheels with an outside-spoke design....
Old Sep 4, 2006 | 02:46 PM
Gjohnson's Avatar
Crap! Man I need some G35 wheels!
Old Sep 4, 2006 | 03:55 PM
6SpeedTA95's Avatar
Why not snag some Brembo Blanks and Hawk Pads?
Old Sep 4, 2006 | 05:52 PM
Gjohnson's Avatar
Well, that's still an option and I might do that until I save up the cash and find some new wheels.
I really want the 300zx brakes, but I need to do something for the moment.
Old Sep 4, 2006 | 05:59 PM
6SpeedTA95's Avatar
You live in BA? Thats sweet...I live just north of Tulsa now
Old Sep 4, 2006 | 06:54 PM
irish44j's Avatar
retired moderator
Hawk HPS pads....definite upgrade
Brembo blanks....no upgrade at all. They don't provide any additional stopping power compared to OEM Nissan rotors, nor any other performance upgrade. The only upside to Brembo rotors is that they're less expensive than stock. That's it. This "brembo rotors are better than others" is a big misperception. Plenty of people have warped them.
Heck, we pulled the 4 new Brembo rotors off Cutler's accord and went back to his old stock rotors, since the Brembos just would not bite as hard
Old Sep 4, 2006 | 07:07 PM
6SpeedTA95's Avatar
Brembo's are cheaper and less likely to warp...doing an entire brake overhaul could definately be a good thing for braking feel but it doesn't always make a difference in real world hard stop scenarios which is why I suggested them. If he's looking to upgrade because he wants to stop faster he better do his homework...if he's upgrading because he wants improved pedal response and a better feel than I say go for it.
Old Sep 5, 2006 | 08:57 AM
9DTALON's Avatar
New calipers for a 6th gen at the dealer are 78$ ea. If you can get a good deal on some rotors and pads, i've got to say it is an awesome upgrade. The best thing I've done to my car so far.
Old Sep 5, 2006 | 09:00 AM
NmexMAX's Avatar
dot dot dot ...
Does anyone have specific weights on the 02/3 rotors vs the 04+?
I still have my old set, so maybe I'll weigh them later today, compare, and post results.
Old Sep 5, 2006 | 04:26 PM
Gjohnson's Avatar
Oh, yeah. Where? Owasso?
9DTALON New calipers for a 6th gen at the dealer are 78$ ea. If you can get a good deal on some rotors and pads, i've got to say it is an awesome upgrade. The best thing I've done to my car so far.
I looked online and Autozone has the 6th gen calipers of around $46 each. I don't see the problem with going with those.
Old Sep 5, 2006 | 05:50 PM
6SpeedTA95's Avatar
Bville, been up here since 05.
Old Sep 6, 2006 | 01:06 PM
9DTALON's Avatar
I looked online and Autozone has the 6th gen calipers of around $46 each. I don't see the problem with going with those.[/QUOTE]
I think they usually sell reman only at autozone. If they are new that is a good deal. I went with the Nissan ones because they are new, and being an employee I got them for closer to the Autozone price.
Old Sep 6, 2006 | 05:15 PM
Gjohnson's Avatar
I think they usually sell reman only at autozone. If they are new that is a good deal. I went with the Nissan ones because they are new, and being an employee I got them for closer to the Autozone price.[/QUOTE]
Hey I understand that, you gotta love the employee discounts.
Hmmmmm..........
Old Sep 6, 2006 | 05:30 PM
carsarecool's Avatar
Crap, so i cant get the 6th gen BBK from having an 01? Or i can get the rotors and brackets, and use stock calipers, just not 6th gen calipers too right?
Old Sep 6, 2006 | 05:54 PM
Gjohnson's Avatar
Right! The 6th gen calipers won't clear 01 stock wheels. The rotors and brackets will clear.
Old Sep 6, 2006 | 05:56 PM
NmexMAX's Avatar
dot dot dot ...
http://www.blehmco.com/relocation_kit.htm
Old Sep 6, 2006 | 06:08 PM
vsamoylov
the brackets will clear any type of wheels. the rotors will clear 00-01 wheels while the calipers will only clear 02-03 wheels.
Old Sep 6, 2006 | 06:12 PM
NmexMAX's Avatar
dot dot dot ...
Matt offers a kit that uses ONLY the 6th gen rotors and retains the stock 00-01 calipers in order to keep the stock wheels..
f'ucking
Any one need me to write it out in crayon again?
Old Sep 6, 2006 | 06:14 PM
vsamoylov
f'ucking
you should make it as your sig
Old Sep 8, 2006 | 12:53 AM
Ride2kMax's Avatar
anybody know how i could order from jeff the kit for the cobra rotor
cant find the link
Old Sep 8, 2006 | 02:16 PM
irish44j's Avatar
retired moderator
cant find the link
um......send a pm to Jeff, maybe
Old Sep 8, 2006 | 05:31 PM
Ride2kMax's Avatar
i did no response from Jeff or Matt.
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
beerman1378
Sep 8, 2015 02:19 PM
iflexsteel
Sep 2, 2015 08:04 AM
