Check engine light
Old Jun 26, 2001 | 03:40 AM
RMcoolX's Avatar
I learned something new today. I took the car to the dealer after getting a check engine light. The service advisor simply turned the gas cap until it clicked and reset the light. Problem solved.
I knew I shouldn't have let the wifey fill up the car!
Old Jun 26, 2001 | 03:45 AM
NuJerseyDrive's Avatar
I had mine come on last week. Tried the gas cap thing, no such luck so I disconnected the battery for a couple of hrs. Reconnected it, light gone and hasn't showed up since. If it shows up again then I'll take her in for a checkup.
Old Jun 26, 2001 | 04:19 AM
[maxi-overdose]'s Avatar
I think it states in the owner's manual about tighten the gas tank cap.
Old Jun 26, 2001 | 04:52 AM
UMD_MaxSE's Avatar
Got Bent?
doh! At least it wasn't something serious
Old Jun 26, 2001 | 07:44 AM
Spoke too soon...
I can't believe it, the damn light is back on! WTF?!
Now I have to deal with Nissan Service one of my worse nightmares.
Old Jun 26, 2001 | 11:34 AM
ispeed's Avatar
Re: Spoke too soon...
try this out ... don't know if it will work but just ran across it, so who knows
http://vbxmaxima.8m.com/ecu.html
Old Jun 26, 2001 | 02:08 PM
2001SE's Avatar
Probably emission problem, it happened to me also, the light just turned on and my i didn't do **** to my car. i took it to the dealer and he told me that the cat is bad so they replaced it for free. I don't understand how a cat can go bad after 4 months.
BTW the dealer told me that if this happenes again they won't replace it. Yeah right!
Old Jun 26, 2001 | 04:00 PM
nizmomx's Avatar
If check engine light comes on and won't go away it could be this problem here. I was at my local dealership at school and one of the technical told me about my buddies 2k Max being in for the check engine light, he told me to bring my car into any dealer and have them check for car out too. Anyway, the problem why the light comes on is because the computer in the car is not reading/diagnosing the correct programming input thus the confusion causes the cpu in the car to put out the check engine light on. To fix the problem you would have to bring in to the dealer and have them reprogram the computer. it's a quick fix. You can also bring it in to the dealership and have them do a check on the ECM card and check the bulletin to see if your car have that potential problem.
Old Jun 26, 2001 | 07:20 PM
Thanks for all the advice. I'm going to the dealer Friday morning. I'll keep you guys posted.
Old Jun 26, 2001 | 09:17 PM
TimW's Avatar
The silent but deadly Moderator
or...
http://www.obd-2.com
you need the ISO... if you were close to me, I'd read it for you.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
