02 headlight question
xlcrew, I believe you have wired them wrong. The HID's are supposed to stay on when the high beams are turned on at the same time. This method is used because it saves the life of the ballast and HID bulb from the quick turning on/off of the HID's.
check the 3rd and 4th gen forums also since their low beams turn off with highbeams. i know of something you can do but i dont know if its recommended. run a diode from the signal on highbeam relay to the signal on low beam relay. that way high beams come on and will leave the coil in low beam relay active but with low beams only, high beams will stay off.
Originally Posted by xlcrew
Is there a way to keep the low beams on when i turn on the brights? just curious thanks
green with white stripe : parking light wire : goes to : red/yellow on nissan
black : ground wire : goes to : ground this wire to the body of car
red : xenon positive : goes to : pink/blue or orange/black on nissan harness with one wire from high beam plug
There are also two wires on the high beam bulbs
If you are looking at the headlight and bulb from the rear
The wire to the left should be spliced with the xenon wire and to the pink/blue or orange/black on nissan harness
And the wire to the right goes to the blue/white or green/black on nissan harness
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
sdotcarter
Sep 2, 2015 09:53 PM
