Battery and Brake lights stay on
Old Sep 22, 2006 | 06:48 PM
ekg2's Avatar
After installing o2 simulator I first got a p0158 code, so I took it off and soldered the cables back together (p0430 back on). Then I installed the simulator again, and this time no CEL came on but I started getting BOTH battery and brake lights on fully lit at the same time (first they went on for like 5 minutes and now they stay on almost all the time). What's wrong? I took the simulator off, soldered all cables back together, made sure they're properly isolated and I'm still having both lights on (plus the CEL came back on). Any ideas?
Old Sep 22, 2006 | 06:51 PM
97Se5spd's Avatar
That usually means bad altenator.
Old Sep 22, 2006 | 06:55 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i would suggest putting the simulator back on and finding an alternator. you can have it tested if you have any doubts but mine did the same thing but at around 45k miles. i found a local starter/alternator shop that had rebuilt ones for cheaper than any other parts place in town.
Old Sep 22, 2006 | 06:57 PM
ekg2's Avatar
usually, but why would it go bad RIGHT AFTER cutting and soldering ECU cables to hook up the o2 simulator. i might have shorted it somewhere? touched two wrong cables together? this is giving me a lot of headache.
Old Sep 22, 2006 | 07:09 PM
sloppymax's Avatar
maybe check to make sure the cables going to the battery are tight but besides that, i dont see where you would have been involved with the alternator itself. im running a simulator that has been taken off once before and never had the issue. i would suggest that its merely a coincedence unless one of the battery cables is loose and the alternator is unable to charge the battery. i would just go to autozone or advance auto for a free alternator test.
Old Sep 22, 2006 | 09:48 PM
ekg2's Avatar
Thought so, thanks, I'll try that tomorrow and post the results.
Old Sep 23, 2006 | 01:33 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
bad altenator
Old Sep 23, 2006 | 12:55 PM
ReMyXe's Avatar
Yep same thing happened before my alternator crapped out halfway through a green traffic light.
Best of Luck
Old Sep 23, 2006 | 03:15 PM
ekg2's Avatar
yeah, mechanic checked it out and yes, it is the alternator. but could o2 simulator installation cause it to go bad or just a coincidence?
Old Sep 23, 2006 | 04:11 PM
xnyc's Avatar
coincidence most likely.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
