Grit or Film on inside headlight....what to do??
Old Sep 27, 2006 | 04:40 AM
zoutv's Avatar
I have a 2000 se
The headlights over time have accumulated some sort of yellowish film on the inside cover. It doesn't appear to affect the actual bulb, or area surrounding the bulb. Not sure what part this is called, but if you put your finger on the outside of the headlight, the film is on the other side.
Is it possible to clean this off? Do I have to buy a new headlight kit? Is the housing sealed, preventing me from getting at it? About how much would it cost to put in a new headlight; parts/labor. Only the driver side headlight is affected.
Obviously from the questions above I'm not very Maxima parts savvy, so help me out if you can.
Thanks!
Old Sep 27, 2006 | 05:21 AM
alicious's Avatar
the org...not what it was
This should help....
http://forums.maxima.org/showthread....ight=Headlight
Old Sep 27, 2006 | 07:34 AM
zoutv's Avatar
Originally Posted by alicious
Well, I think the film is on the inside of the unit. I'll double check, but I remember that I did not feel anything on the outside of the lamp...so I think its inside.......
Old Sep 27, 2006 | 07:58 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Our headlight plastic (and other cars too) has a tendency to get yellow/hazed. Even if you can't feel it on the outside. I'll wager that by polishing it as mentioned in alicious's link will clear it up.
Old Sep 27, 2006 | 12:11 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
If for some reason it doesn't clear up after you do the polishing method in the link above then search & find the how to on breaking your headlight apart and repeat the same method on the inside.
litch
123
Jan 4, 2024 07:01 PM
sctludwig
Sep 1, 2022 01:32 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
carid
Sep 17, 2015 05:00 AM
