Gas needle stuck again
Old Sep 29, 2006 | 10:45 AM
Y2K1GLEMAX's Avatar
I filled up my gas yesterday and the needle got stuck. It's done it before but it fixes itself after a while, so I never fill up the gas. This time I just want to fix it. Any input would be appreciated.
Old Sep 29, 2006 | 10:57 AM
Colonel's Avatar
Old Fuddy Duddy
Where is it getting stuck? Not showing full or not going below a certain level?
Does it move at all?
Have you replaced your fuel filter or anything in the fuel pump sending unit?
Old Sep 29, 2006 | 11:31 AM
Y2K1GLEMAX's Avatar
It's getting stuck at full. It goes down when i turn the car off and up when i turn the car on. I haven't ever touched the fuel filter or the pump. Thank you
Old Sep 29, 2006 | 11:43 AM
Colonel's Avatar
Old Fuddy Duddy
I would suspect your sending unit is bad. There are troubleshooting instructions using a DVM to check current coming from the unit. You should be able to test this without having to pull the unit. You should only have to remove the back seat to access the connectors.
A misinstallation can cause this problem, which is why I asked about that. Otherwise you are looking at a short most likely.
Old Sep 29, 2006 | 12:16 PM
MacGarnicle's Avatar
I dunno if we're having the same thing but... when I do a full fill up, the needle goes way past the F line and it stays there for around 100km or so then comes down. I don't think it's stuck, its just more full than the fuel gauge can show...
Old Sep 29, 2006 | 12:24 PM
Colonel's Avatar
Old Fuddy Duddy
I would almost laugh if that was the issue. And then I would have been
I guess I assumed "basic" troubleshooting had already been done.
Old Sep 29, 2006 | 12:25 PM
Y2K1GLEMAX's Avatar
Where can I locate these instructions? Thanks again
Old Sep 29, 2006 | 12:27 PM
Colonel's Avatar
Old Fuddy Duddy
ESM
Electronic Service Manual
Old Sep 29, 2006 | 01:26 PM
Y2K1GLEMAX's Avatar
How can I get my hands on one?
Old Sep 30, 2006 | 09:59 AM
Y2K1GLEMAX's Avatar
I was thinking, it only does it when I fill the gas. If it were a short then it would do it all the time, right? I don't know very much, but I think the sensor in the gast ank might be bad.
tarun900
19
Dec 20, 2021 06:57 PM
ef9
Oct 4, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
