quick question... about headers...
Old Sep 29, 2006 | 02:32 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
on a 01 we have a pre cat on the front header... would it be smart... to change that header to the an 00 fed spec header... or its just not even worth that much trouble for that tiny pony...
Old Sep 29, 2006 | 07:25 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
it has been done and proven not to be worth it. this was of course pre-header days. i would suggest a ypipe for a nice gain and easy install but would still leave 1 precat in tact. that or go with headers and replace the exhaust manifolds so you have no precats then an afc to tune the richness typically caused by the headers.
Old Sep 29, 2006 | 07:45 PM
KabirUTA13's Avatar
y pipe alone... do u still need to tune it
Old Sep 30, 2006 | 07:24 AM
Puppetmaster's Avatar
Most likely not, but you'll never know unless you get a dyno with AF reading or use a wideband.
And to add to Sloppy's point, look for Desert Pearl's thread in the Stickies and you'll see his dyno results before and after his FED spec conversion. IIRC he only gained about 4 whp from the conversion over just a y-pipe.
The flow restrictions are in the design of the stock headers, not the pre-cats. If you're gonna replace your exhaust manifolds, get some equal length headers like Cattman or Hotshot.
Old Sep 30, 2006 | 07:54 AM
sloppymax's Avatar
+1 to what joel said. my a/f was just about dead on 13:1 with my old cattman y pipe. the headers richened it up quite a bit.
Old Sep 30, 2006 | 08:39 AM
Old Sep 30, 2006 | 08:59 AM
KabirUTA13's Avatar
ok great info thanx... but thats only if they make the front header equal in length as the stock manifold tho.... i'll check up on that... thanx for the info
Old Sep 30, 2006 | 02:33 PM
KabirUTA13's Avatar
jus a quik question to anyone that has an aftermarket header system... how can u physically compare both the stock front header and the aftermarket one... im talking about not appearance but more like the length of it how close to stock header does the aftermarket header look like... ex: meowman headers the 3 to 1 collecter is longer than the stock one... suttin like that type of comparison...
the reason im doin this is... spending close to 900 bucks for the system and then the installation... im running up close to 2 grand i figure the front header is easier much easier by far than the rear and from my understanding the rear header doesn't have a precat and the front does.... just as puppet mentioned about desertpearl and how he gained 4 horses... that better achieved than none... thanx for the help
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
