What could it damage???
Old Oct 5, 2006 | 07:47 PM
Mints33's Avatar
Yeah ... stupid me, when I was bleeding my brakes, I spilled brake fluid while filling up the reservoir, I was looking at the reservoir while pouring and didn't realize how much fluid there was in the funnel, didn't think it was so slow so a whole bunch got all over the master cylinder and whatever else as it came splashing on my garage floor, what a mess!!! Anyhow yeah, just plain ole' careless and dumb!!! Anyhow, I know brake fluid can ruin a painted surface, however can it damage engine components? I tried to wipe everything off as best as I could, but I'm sure there are tight spots I couldn't get at. Any thoughts or comments welcomed!!
Old Oct 5, 2006 | 08:16 PM
bsetiawan's Avatar
If the fluid that you spilled is new, don't worry about it. Otherwise, you can always use aerosol brake cleaner and spray liberally on the area that was spilled on. You can also take it to a detailing place that offers engine steam cleaning if you still don't feel comfortable with just the brake cleaner.
Old Oct 6, 2006 | 05:05 AM
bladerunr's Avatar
Hit the area with engine cleaner, simple green or one of those fruit acid based cleaners. Rinse with water and you'll be fine. Just don't let fresh brake fluid sit on any surface too long.
Old Oct 6, 2006 | 09:37 AM
Mints33's Avatar
Got two different answers here, it was new fluid that spilled, can anyone else confirm?
Old Oct 6, 2006 | 10:00 AM
bladerunr's Avatar
Why are you taking chances? Brake fluid is corrosive. No matter what you spilled you should clean it up immediately.
Old Oct 6, 2006 | 04:17 PM
limsandy's Avatar
I'm sorry to hear that.... I suggest you'd better replace your engine ASAP.
Old Oct 6, 2006 | 05:12 PM
bashboy2000's Avatar
your a real wisen heimer smart guy
Old Oct 7, 2006 | 01:48 PM
super6's Avatar
ye, defenatly use simple green, that stuff is awesome!
Old Oct 7, 2006 | 03:17 PM
Mints33's Avatar
Old Oct 8, 2006 | 11:29 AM
Matt_01SE_20th's Avatar
dont worry about it. you would need a quart of brake fluid in a puddle that was between two different materials to truly cause a problem ont he engine. still, clean it up anyway, it will just collect dirt, run down the engine, make you think you have something leaking, etc. make sure you do clean up areas of close clearance, AC LINES, ELECTRICAL CONNECTORS, ETC. dotn worry about the corrosive properties of the brake fluid itself, but be sure you dont create a corrosion cell.
Old Oct 8, 2006 | 02:00 PM
Mints33's Avatar
I stopped worrying about it after I cleaned it up as best as I could. I spent a couple of hours cleaning it, at least, to the best of my knowledge, it got cleaned up so case closed. I'm still not happy at the fact that it happened, but it could've been worse. Now, I gotta do my wife's van next weekend, I hope I don't screw up again. This time I'll be wrapping the reservoir tank w/ several towels to prevent such accidents.
litch
123
Jan 4, 2024 07:01 PM
doctorpullit
Apr 23, 2017 05:35 AM
Marc2theMax
Sep 28, 2015 08:13 AM
