Car stalling in neutral, any ideas
Old Oct 6, 2006 | 04:10 AM
ryand.white's Avatar
I have a 2000 5 spd max and lately the car has been stalling when I come to a stop. I hate down shifting when I slow down, but it seems like that what I have to do to keep the thing from stalling. Sometimes that doesn't even help. It's kind of embarassing. People might think I don't know how to drive a standard! haha. I know I need three knew coil packs, but this hasn't caused a problem in the past. Injectors? MAF? any ideas. The air filter was just replaced too, so I know it's not that. It was stalling before the air filter, so that didn't cause the MAF to go, but who knows, the dirty filter might have done it. Any help at all would be great. I know there are some knowledgeable maxima enthusiasts out there with some ideas.
Thanks again guys.
-ryan
Old Oct 6, 2006 | 05:21 AM
Rydicule's Avatar
Don't you know who I am?
I've seen this problem before in a 2001 Max. Would stall when going around turns with the clutch held down and while coming to a stop. I don't believe it really stalled while at a stand still idle, however, it did have a habbit of dipping the RPMs low and then recovering to idle speed.
Changed the MAF, cleaned the throttle body and IACV.
Seemed to do the trick. I would recommend the latter before spending the $ on a MAF, unless you are experiencing other symptoms typical of a failing MAF sensor.
Old Oct 6, 2006 | 05:23 AM
trigger005's Avatar
sound advice
Old Oct 7, 2006 | 01:49 PM
super6's Avatar
had the exact same problem its 99% the MAF, but try to cleaan the TB first, defenatly w/o a doubt one of those two things.
Old Oct 7, 2006 | 03:08 PM
Mints33's Avatar
Anyone have a pic of where the IACV is located? Thanks much!
Old Oct 7, 2006 | 04:55 PM
bashboy2000's Avatar
uuugh this is what my car is doing i dont want to fork the money for the maf. plus coil pack four is hitting fault every other week. i'm saving up for new coil packs and plugs after i change them if it goes away i'll let you know. but when mine does this problem its usually if soon after start up i drove it agressive then whenever i push the clutch down and am approaching a stop it dies but once again putting it in gear with the clutch still engaged usually saves it. i ussualy go for second gear glides in smoother
Old Oct 8, 2006 | 06:26 PM
Exact same symptons man. I'm gonna try cleaning the throttle body first. I doubt it will work, but who knows. It's all I can do at the moment.
Old Oct 8, 2006 | 07:24 PM
BUSi87's Avatar
Buy maf cleaner spray and see what happens...
I had the same problem and i cleaned my maf and it ran fine, even my mpg increased.
Old Oct 8, 2006 | 07:40 PM
† ErV †
your maf is different.
00 need to change theirs.
Old Oct 10, 2006 | 03:51 PM
still waiting on cash before my attempts to fix this happens
Old Oct 10, 2006 | 04:25 PM
super6's Avatar
might as well try to clean the tb for now.
Old Oct 10, 2006 | 07:04 PM
NismoMaxm's Avatar
I had similar problems and i changed my MAF and cleaned the throttle body and the low idling and almost stalling stopped. It wont hurt to try except the MAF was like 100 bucks i think.
Old Oct 11, 2006 | 02:22 AM
EastSideMaxima's Avatar
A swift Bimmer driver
Its gotta be the MAF...
It happened to my '02 Max, Good thing the A/M warranty kicked in to cover it.. Atleast yours in only around $100 compared to the $450+ for the 02-03s
Old Oct 18, 2006 | 02:50 PM
well i changed coilpack number four the maf and did the seafoam thing to clean all at the same time haven't drive more than a half a tank since but hasn't done it again sorry i didn't isolate the issue for anyone i just needed to get it all done so my two cents is clean and see how it goes i just went all out
Old Oct 18, 2006 | 09:05 PM
JiggaD369's Avatar
How do you properly clean the throttle body and IACV for 5.5 gens?
Old Oct 18, 2006 | 09:58 PM
getbigtony's Avatar
how do you clean the IAC? is it right behind the butterfly plate?
Old Oct 19, 2006 | 06:43 AM
zheka's Avatar
i had the same exact thing happen to me, and it was the senser right under the throttle body intake (i can't remember whats it called).
Old Oct 19, 2006 | 10:55 AM
super6's Avatar
the iacv id underneath the tb, held together by 4 small and one long screw, becausefull they srrip very easy, and be sure to get a new gasket when reassembling. just take it all apart, u can use brakleen on it, remember the position of everything, especially the TPS (making a mark is recomended).
Old Oct 19, 2006 | 01:33 PM
JiggaD369's Avatar
Anyone know how to PROPERLY clean a 02 throttle body?
Old Oct 19, 2006 | 04:55 PM
all i did was suck seafoam throu the brake boaster vacum tube it was very easy
Old Oct 19, 2006 | 06:31 PM
JiggaD369's Avatar
That doesn't clean the throttle body as far as I've read.
Old Oct 20, 2006 | 12:16 AM
getbigtony's Avatar
if you are using this "seafoam" agent in your brake booster vacuum line, why not just use ATF? ATF has soap additives and will clean everything nicely
but.. super6, got pics? or anyone else for IAC removal
Old Oct 20, 2006 | 03:44 PM
Nomad's Avatar
Sigh I cleaned my IACV yesterday that was real PITA. For those who' gonna attempt to clean it, use screw gun with flat bit to deal with those screws.
BTW super6 where do you get new gasket? I've cleaned my IACV but situtation didn't change. When I start engine in the morning car stalls and i have to pinch and hold pedal for a while. Does anyone know what a problem could be in my case?
Lakersallday24
Jun 16, 2019 01:35 AM
beboski
Aug 16, 2015 05:23 PM
erniel
Aug 8, 2015 09:32 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
