Driver side heated front seat question
Old Oct 23, 2006 | 08:27 AM
jafo2com's Avatar
I have a 2002 SE with heated front seats. The problem is that the driver's side does not come on anymore, but the passenger side does. My question is whether or not there are any other fuses controlling the seats besides the 10A one in the inside fuse panel at position #9. I do not believe there are any, but I thought I should ask in order to verify. That fuse is not blown, so I have a feeling it's just the toggle switch. If it is the only issue, how involved is the removal of the center console? It it is not too bad, I will swap the switches until I can get a replacement part. Otherwise I will wait to get the part first. Please advise as the weather here in the midwest is starting to get a bit chilly. Thanks in advance!!
Old Oct 23, 2006 | 08:33 PM
cobalt416's Avatar
I have a similar situation. The bottom part of the driver's seat is not heating up anymore, but the back side it heating up...
Old Oct 23, 2006 | 08:36 PM
SoonerFan's Avatar
Cletus
sounds like something with the switch or the heating element
Old Oct 23, 2006 | 11:09 PM
asianstyle's Avatar
i have an '01, I turned my seats heaters on and on the driver's side, my back warmed up but the bottom did not. the picture on the switch shows that the bottom is suppose to warm up not the back part. and on the passengers side it warms up on the bottom.
Old Oct 24, 2006 | 04:40 AM
jafo2com's Avatar
Thank you all for the replies. Unfortunately I pulled one of the major newbie no-no's one should not do before posting a thread: always always ALWAYS fully troubleshoot and never assume. Note to self - just because the light is out, it doesn't always mean a feature is not working. I was able to enjoy a nice comfortable ride on my way into work this morning after all, even with the lovely traffic issues.
Hrmmm...I wonder if I'm daring enough to rip out the center console and the switches to replace the bulbs with LED's ala MetalMaxima-style. Let me think about that one for a second...uuummmmmNOPE!!! ( to MetalMaxima however!)
Anyway, my apologies to the forum. Moderators, feel free to remove this thread if you like.
To asianstyle - I am assuming your car has the same toggle switch as mine (I didn't have heated seats in my '00). According to the ['02] owner's manual, the picture on the switch does not relate to the bottom or the back. Instead, the "fatter" line on the front side of the car means High while the "thinner" line on the back side means Low.
Old Oct 24, 2006 | 09:03 AM
Sari's Avatar
I have the exact same problem. Anyone have any ideas on what would cause that?????
Old Oct 25, 2006 | 08:48 AM
CVicVogel's Avatar
Yep! I have the same problem!! Bangers! What to do???
Old Oct 25, 2006 | 03:52 PM
Dust N Bones's Avatar
The heating coils are bad. This happened to my 02 when I first bought it. The dealer paid for it under good will because I only had the car a few days when I noticed it but I believe it was expensive to fix.
Old Oct 25, 2006 | 05:18 PM
Dayo's Avatar
Happened to my 2000 Max last year, had to have the heating coil replaced, can't remember exactly what it costed, think it was around $600.00.
Old Oct 25, 2006 | 06:15 PM
sascuderi's Avatar
Hey, the driver side seat hasn't worked in my 2000 I30 for two years. The light is fine, so I suspect it is a bad heating coil.
Don't want to spend $600 to fix it!!!!!!
Any suggestions on doing the repair yourself? Any other options/ideas?
Old Oct 27, 2006 | 09:58 AM
Sari's Avatar
Yea I don't want to spend $600 either! Are there other options? I've seen some aftermarket coils online for $100 that claim "easy installation". I've never removed a seat with an airbag and even worse never had a seat taken apart. Anyone know if they really are "easy" to install? Any other ideas??????
Old Oct 27, 2006 | 06:28 PM
sascuderi's Avatar
Anyone know how to remove the seat cushion without taking the seat out of the car?
(That would allow access to the heater coils in the seat and maybe they could be fixed)
Old Oct 28, 2006 | 10:49 PM
trigger005's Avatar
i have the exact same problem as all of u with my driver side seat
my solution was simply to buy a new set of seats
it was an upgrade and a lot less than $600
Old Oct 29, 2006 | 07:32 AM
sascuderi's Avatar
Where the new seats "plug and play" for the heater, airbag, and seat motor?
Where did you get them?
Cost?
Old Nov 22, 2006 | 10:38 AM
Aeiceman's Avatar
My switches are pushed toward the dash,or down, for high heat and pushed toward the rear, or up, for low heat. Anyway my drivers side bottom has quit also.
Old Nov 27, 2006 | 06:29 AM
Bborges's Avatar
I turned my seats heaters on and on the driver's side, my back warmed up but the bottom did not. and on the passengers side it warms up on the bottom.
huahauhauah
I have the same problem:
drivers seat: back heat only
passenger seat: butt heat only.
Now, I dont care much about the passenger seats... so is there anyway I can swap the butt heater coil from the passenger to the drivers seat?
Anyone knows anything about that?
Thanks!
Old Nov 30, 2006 | 10:16 AM
nicks79's Avatar
see if its the same part number, then you should be able to.
Old Dec 1, 2006 | 12:14 PM
Digger01's Avatar
heated seats
I installed a set of aftermarket seat heaters in my truck.. They work great and get really hot on high.
The install required removal of the seats from the car but if your creative you can do a couple of tricks to minimize the job.
My seats cam apart easily since the they used plastic clips to hold the fabric to the seat cushion. So I only lifted the fabric enough to slide the heating elements into place (then I applied pressure to activate heater element adhesive-two sided tape). I ran the wires so as not to get pinched into center console and then ran a wire to the power source. (I had to run power from the heating elements to a fuseable link in my fuse box.)
Cant find the info, but the web site seemed to have ford cars and he did have a ebay store. I think it was -seat heater kits
I went with these after some research, these had a two position switch with a light for low/high, and the rep was very helpful.
Old Jan 15, 2007 | 02:55 AM
lalaMAX's Avatar
i have the same problem too... the driver side "back only"... passenger side works fine... orange light on both switch are fine!
hope someone can find a cheap solution...
Old Jan 15, 2007 | 03:13 AM
lalaMAX's Avatar
can we replace anything like http://cgi.ebay.com/ebaymotors/2-Sea...QQcmdZViewItem
Old Jan 15, 2007 | 01:13 PM
MerlotMax's Avatar
Have you guys taken a look back at some of the post, found this a while back. http://forums.maxima.org/showthread.php?t=501543
Old Aug 19, 2007 | 03:57 PM
STILLENGLE's Avatar
Sorry to bump this thread but iam having the same problem my driver seat is not heating up the switch doesnt work but the passenger does.
Old Aug 19, 2007 | 04:23 PM
STILLENGLE's Avatar
thanks iam going to take it in for service sometime this week. so ill see what they say.
vingodine
45
May 21, 2016 12:46 PM
rtirbany
Sep 8, 2015 11:46 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
BassAddictJ
Aug 4, 2015 11:38 AM
