AE Fog Light Replacement - How to's
Old Nov 4, 2006 | 10:19 AM
stefnee's Avatar
I found the steps to replace the foglights on a 01 Maxima, but it did not state whether the same steps are used for an AE. Has anyone changed the foglight bulb on an AE? If so, which instructions did you use?
Stefnee
Old Nov 4, 2006 | 10:33 AM
meccanoble's Avatar
Sports Button FTW
same exact thing. the 02+ are a little different in removing i believe but 00-01 AE are all the same, i'm 99% sure. Just unscrew from bottom.
Old Nov 5, 2006 | 03:01 PM
stefnee's Avatar
Instructions worked
I was able to replace the foglight bulbs from the excellent instructions Kevins has on supplied (http://www.cardomain.com/ride/2076435/2), using the same bulds, however, the right foglight seems brighter than the left.
Any suggestions on tips on why that would be?
Old Nov 6, 2006 | 09:31 AM
MacGarnicle's Avatar
The AE model's fogs are no different from the normal 5th gens, unlike the headlights. All AE's have fogs, unlike other models, but they're the same!
Old Nov 6, 2006 | 09:54 AM
00MaxSE's Avatar
Pointy Elbows
One of them is probably not aimed correctly. The little white **** can be turned to adjust the fogs. I'd use a socket insted of a screw driver since the plastic is kinda fragile.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
