Radiator Hoses replacement
Old Nov 6, 2006 | 03:52 PM
dansmax2003's Avatar
My car (2003) has close to 90k miles on it. I was wondering if i should replace my upper and lower radiator hoses. Visually they look fine, but 90k miles on them is not a joke. I drive a lot and i don't want any of them to burst, especially when i go snowboarding this winter.
Has anyone replaced radiator hoses on their 5th gen already?
Is it necessary for me to do it at 90k miles or i can safely wait longer?
Any tricks when replacing them? Can't be that hard, but i've been wrong before.
A local auto-shop asked $189 to replace both of them. I'm planning to do the work myself and save $$. ..i just don't want to do it if it's still safe to use the original hoses.
Thank you for any input.
Old Nov 6, 2006 | 03:59 PM
SoonerFan's Avatar
Cletus
unless you see dryness or cracking they should be fine. but it wouldnt hurt to change them.
its very easy to do..
drain radiator
remove the four clamps
remove hoses
VaporHead
Simple replacement. It requires obviously draining system, and pulling them off, or cutting them off it stuck. If they visually look good, and are still fairly firm but not rock hard, then you probably dont need to replace them. I've hard a few cars with well over 120K on them with original hoses.
Old Nov 6, 2006 | 04:07 PM
Thank you for the replies.
For some reason, i am having a very hard time finding LOWER radiator hose for my Maxima. Looks like no one sell them.
Old Nov 6, 2006 | 06:23 PM
inspiredbykev's Avatar
You should thank my D***
samco sells radiator hoses for our car.
Picked some up off of importrp.
Old Nov 6, 2006 | 08:55 PM
Love_00_Max's Avatar
I replaced my hoses along with a new radiator a few months back. I got Gator hoses, went to their website and called local authrozied dealer who incidently had it in stock. In the Bay Area, Gator has a big wearhouse, so it was easy for me -- both hoses costed me $50.
Old Nov 6, 2006 | 09:11 PM
DAP's Avatar
DAP
I wouldn't worry about it. Time is more of a factor than miles. Good OEM hoses last a long time. If you are going to replace the radiator hoses, might as well do the heater hoses and thermostat while you have the system opened.
Old Nov 7, 2006 | 10:25 AM
Where exactly did you find Gator hoses? I used Google but not much luck. Is the name spelled corectly?
Thank you!
Old Nov 7, 2006 | 10:46 AM
bladerunr's Avatar
I never replaced the hoses on my 94 and I sold it with 190k on it. Don't waste your time hunting down hoses to save a few bucks, just buy the Nissan stuff and be done with it.
Old Nov 7, 2006 | 10:56 AM
OC guy's Avatar
2002 maxima se
ya they dont need to be replaced unless your car has over 200k just get the radiator drain and fill on every 30k
Lilchikcadee
May 1, 2019 08:49 AM
hydriplex
Aug 28, 2015 02:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
scarletsosa
Aug 17, 2015 09:09 PM
acw
Aug 7, 2015 04:20 PM
