5.5gen IM question
5.5gen IM question
It is my understanding that the 5.5gen intake manifold secondary runner is closed between 1800-3500 rpm. While it makes sense that the secondary runner opens past 3500 rpm, could someone please explain the purpose of it being open prior to 1800 rpm? I would think keeping the IM closed by default would benefit low rpm response...
Maxima's variable air intake system features an intake manifold that "breathes" differently at high and low rpm. You get rich torque off the line; then, as speeds rise, a shorter air flow path opens to unleash deep reserves of passing power.
video of how it works http://www.nissanusa.com/maxima/gall...ke_System.html
There are no secondary runners.
I've dynoed open and closed and have other dynos that show the way it is from the factory, is the ebst for torque
That video is invalid because the 2k2+ Im is far different.
I understand what you are saying but the diagram is actually incorrect: Until ~1800rpm both runners remain open. I question the reasoning behind this, as it seems counterintuitive, no?
EDIT:
Technically there are no secondary runners, but the intake manifold is variable. Does it not restrict airflow between 1800-3500 rpm?
EDIT:
soonerfan: Yep, but unfortunately, it's inaccurate.
Others:
There are no second runners people, can you not read?
Click on the FWD version and then click the IM, theres a cutaway view for the IM
http://www.nissanusa.com/stories/?Cu...e:::MDLMAXHome
Others:
Others:
Others:
It's a strange IM
My guess is that it was made to compensate for lack of VTC tq the G/Z gets, and was given that weird design. But this also makes high rpm power suffer.
Here a an **** load more pics
http://www.cardomain.com/ride/301377/9
.My guess is that it was made to compensate for lack of VTC tq the G/Z gets, and was given that weird design. But this also makes high rpm power suffer.
Sucks the butterfly shut.
It's actually 3600 RPM (FSM)
2k2/3 phsycially the same, 2k4+, EGR stuff added but functionally the same.
http://forums.maxima.org/showpost.ph...3&postcount=14
So...what function does that vacuum operated actuator mounted to the passenger side of the intake manifold perform by changing position first at 1800rpm and then again at 3500rpm?
i thought you said 2k2 was different for some reason
Originally Posted by NisTech
i remember looking up 03 in the manual and it said it opens at 5500
Originally Posted by nismology
You were corrected in another thread by Puppetmaster and me about this same exact thing. Per the FSM, it is closed from 1800-3600 RPM and open otherwise.
He's asking why it's OPEN below 1800? and it is true...from idle (650rpm) all the way to around 2k, i notice it stays open...thats according to me watching the actuator, with someone revving the engine
this is why i got confused at first...cuz originally, i came from a 4th gen maxima...we had MEVI and 00VI's....their designs had butterfly valve in each runner...and they stay CLOSED until a certain RPM....where as the 2k2 IM, they stay OPEN....then CLOSES...then OPENS again...pretty strange i know....thats why i THOUGHT that zip tying the actuator on the 2k2 IM would keep it stuck open....when in fact, it's keeping it stuck shut...
Originally Posted by kobalt
But why is it open at < 1800 ?? It seems counterintuitive and does not seem helpful in terms of off idle engine response...that's been my question all along
Originally Posted by Puppetmaster
I honestly don't have a good answer as to why its open below 1800, but does it really matter? When are you ever driving at < 1800 rpms? If you're worried about low end torque at 1800 rpms, then you should just downshift.
The motives for my inquiry were much less complex: I simply found the IM operation design somewhat bizzare, thought it warranted a question and that perhaps someone had an answer. Now we officially know otherwise
I just find it weird how Nissan had other VIAS such as 00vi and MEVI...that is closed during default, and opened at a certain RPM...then when they designed the 2k2 VI, its default is OPEN....then it closes, then opens again...I mean, why couldn't they just stay with the same setup? it just seems logical to keep it shut for idle to 3800 performance...
Which manual is this and where in the manual does it say that? I'm curious to know.
In our dealership we use original Nissan ESMs.
I never had to look that up for any issues but i remember reading about it while i was just browsing.
I will look it up tomorrow again if i remember...
If you are so positive i am sure you are right. Like i said not much experience with that.
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
im going crazy i thought you said 2k2 was different for some reason
