Any Way to Extend the Redline???
Old Jun 30, 2001 | 06:23 PM
2000 SE's Avatar
I find it a little odd that the max HP is at like 6400 when the redline is 6600! Is there anyway to override the redline with an ignition for example? I was just thinking that when I hit 3rd gear it seems to fall a little to low in the rpm's.
Old Jun 30, 2001 | 06:36 PM
Sonic's Avatar
I believe that you can get your ECU reprogramed to do this, but does anyone do this right now? It may still be in the R&D stage.
Old Jun 30, 2001 | 07:10 PM
2000 SE's Avatar
With the MSD ignitions (on V8 cars) you could change you redline by changing a chip in the ignition.
I just think this motor is capable of much more.
Old Jun 30, 2001 | 08:12 PM
Desert Pearl's Avatar
The MSD ignitions for our car can come with an adjustable rev limit, however it was intended for use as a stutterbox. In otherwords it is a second rev limit... it can't override the one in our ECU. I wish I knew if our rev limit was software encoded or hardware. On my previous Eclipse, the top speed limiter was just a resistor on the ECU, which could be removed, thereby removing your top speed limiter. I'm assuming a different sized resistor would adjust the speed accordingly, but no one ever tried this (why would they... no limit is better). However on our rev limitter, I'm not sure if this is how it's setup. I suspect it's encoded in the software though (meaning no adjustability).
Old Jun 30, 2001 | 09:24 PM
footemps's Avatar
Hm...If it's software...I wonder if anyone could hack it.
Old Jun 30, 2001 | 09:39 PM
UMD_MaxSE's Avatar
Got Bent?
it is software......just need to figure out what language the code is in....probably assembly so it depends on the processor they are using.....I know a bit motorola RISC assembly language.....now, someone get me the source code
Old Jun 30, 2001 | 10:04 PM
footemps's Avatar
hahahaha! GO UMD!!!
user 11122324
42
Jul 18, 2022 03:35 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
3rdmaxse0
Aug 18, 2015 08:25 AM
1997 Maxima SE
Nov 24, 2000 01:37 AM
