Does the stillen brake upgrade work with 18's?
Old Oct 17, 2000 | 12:18 PM
EdV2K's Avatar
Just wondering, cause in the catalog it says that you must have 17's for the upgrade. But i've seen at various shows 2K Maximas with the crossed drilled stillen rotors wearing 18 inch wheels. Whats up with that, cause i have 18's and want the upgrade if possible.
Old Oct 17, 2000 | 12:24 PM
xtantmaxima's Avatar
Yes it will work, if Stillen is making it for the Y2K+. The reason that they specify 17" rims is because the rotors and caliper are larger than stock, which means that you need more space in your wheel. This is the reason that big money cars have big wheels, to clear the calipers and for cooling purposes. So the bigger the better.
Old Oct 17, 2000 | 12:38 PM
PIONEER's Avatar
True once again, bigger rims and tires are not the problem, its smaller ones. if your disk is 13inch and the caliper is another 2inch on top of the disk and U R running 16inch rims, U would have a problem with cooling. so 17, 18, 19 would be no problem. Just don't get ACME breaks, Slam them too hard and the Body might come off the Chassis like the cartoonz
jerrod99_se-l
Aug 27, 2015 08:27 PM
cheftoo
Aug 20, 2015 05:17 AM
Team STILLEN
Aug 10, 2015 04:29 PM
kenc15
Aug 5, 2015 08:29 AM
