Who here with an 02/03 6mt has NOT had a 3rd gear crunch?
View Poll Results: Rate your 3rd gear "crunch" occurrence
No 3rd gear "crunch" at all
45.29%
Yes- its a prevalent occurrence
19.28%
Its happens occasionally
36.32%
Multiple Choice Poll. Voters: 223. You may not vote on this poll
Dec 8, 2006 | 01:49 PM
  #81
Quote: I just put new Amsoil gl4 gear fluid about 2 months ago. Is it ok if I switch to redline mt90 so soon? I heard tranny fluid is not something to be changed that often.
You can change it everyday.
I would run this application next time as half mtl half mt90. Our trannys take about 2.3-2.5 l of fluid. Just get yourself 3 bottles. Actually because we get sub zero temps more mtl than mt-90 would make it shift better as per redline tech.
Dec 8, 2006 | 02:01 PM
  #82
Quote: Nistech --
Thanks for the professional input.
I changed over my trans fluid @ 15k, and I'm now @49k.
I used Amsoil Series 2000 100% Synth 75w-90, rated API MT-1, GL-2 THRU GL-5. I did this SPECIFICALLY because I was having the notchy/crunchy shifting problem, even then.
Is it safe to assume that I didn't use the wrong lube, in terms of GL rating?!
In any case, if I were to bring my car to your shop and say I was having the third-gear grind issue -- I'm assuming the FIRST thing you'd do is test it (it crunches) and then you'd CHANGE the LUBE, and send me on my way for another 1000miles or so, and then to come back for retesting. All this BEFORE you made the call to swap / rebuild the tranny under the 60k warranty.
Does that sound about right?
Are there any further stipulations that Nissan will enforce in regards to the service / condition of the vehicle, or it's service records?
I've maintained this thing very well - but I have never sought service from a Nissan Dealer OTHER than for warranty work? By my account, the OM doesn't even recommend changing the trans fluid b4 60k, correct?
Thanks.
gr
You cannot run GL5 as i said. You will wear out your synchros. Those additives attack brass and soft material synchros. I would not buy a gear lube that is ok for all GLs. It does not make sense. Think about it! gl5 =gl4 with 10 times the additives so how can it be both or ok for both.
You are correct on the second issue. However dealers like it when you do the maintenence there. Think about it. You go to chain shops for your brakes fluids etc. Besides how do we know what they use? (of course we can't assume they always **** up) You'll find that if you do work there they will be willing to help you a lot better. Better service history with records.
But i would just swap that fluid first and i'm sure you'll be happy. If not just go in january when the shop is slow and try going once, twice, perhaps a different dealer.... You get my point? Get second oppinions.
I almost was thinking about warranty tranny before redline but now it shifts fine. No reason to screw around with it if it's fine. Even if it was free you get my point?
Dec 8, 2006 | 02:36 PM
  #83
whats the 3rd gear crunch problem. im new so i never heard of it. i just got my max so im not aware of this.
Dec 9, 2006 | 08:37 PM
  #84
Quote: You cannot run GL5 as i said. You will wear out your synchros. Those additives attack brass and soft material synchros. I would not buy a gear lube that is ok for all GLs. It does not make sense. Think about it! gl5 =gl4 with 10 times the additives so how can it be both or ok for both.
What about Royal Purple 75w90? The label says that it's ok for applications requiring GL-4 and GL-5.
Dec 10, 2006 | 07:41 AM
  #85
Only seems to happen when the weather is cold. When I was living in Boston it happened more often, but now I am in Florida it doesn't happen very often except on chill mornings........It's not something I am concerned about
Dec 10, 2006 | 08:06 AM
  #86
I'm a little curious. Nissan is willing to replace the transmission under warranty...but are the new transmissions that they're putting in any better? Is the 3rd gear synchro fixed? I'm contemplating a 6 speed swap and if i do I'd prefer not to have this problem
Dec 10, 2006 | 09:42 AM
  #87
they are putting in the 6th gen 6speed tranny's
Dec 11, 2006 | 07:27 AM
  #88
3rd gear crunch
I'm at 30,102 and no problems at all.
Dec 11, 2006 | 09:38 AM
  #89
I only seem to notice the "crunch" when I am pushing the car. I.E. Downshifting without double-clutching to pass someone, during hard and fast acceleration when I shift into 3rd. I think that's the only time I feel it. Other than that, during normal driving, it falls right into gear when I shift on or near the shiftpoint.
Dec 11, 2006 | 11:21 AM
  #90
I've had my transmission replaced at about 40k miles due to the 3rd gear crunch...I noticed it did it every time I was coming up to a toll both from 5th or 6th gear and attempting to shift into 3rd...no go. I have 117,200 now and I think that its starting to come back. I'm going to rebuild if it gets worse....
Dec 13, 2006 | 06:04 AM
  #91
oops, didnt see it was for 02 before i voted on front page;
i got 1st gear synchro problem though =)
your crunch is probably from the synchronizer as well
Dec 13, 2006 | 08:04 AM
  #92
Started with it but gone now
I bought my 02 se 6spd with 18k miles in 04 on it and had it quite regularly whenever I would not get the clutch all the way in and try and do a quick shift. I moved my seat closer and made sure I had my clutch all the way in and took my time getting it into 3rd gear and as long as I do that I don't have the problem. It is interesting that the quick shift didn't seem to happen on any other gears though. BTW it has 109k on now and I need to sell because I use it for work and my company doesn't reimburse me adequetely beyond 100k. Anyone interested email me at greg.stagner@gmail.com
Dec 13, 2006 | 01:48 PM
  #93
just an update...for the past 4 days I have experienced NO crunch in 3rd at all...the weather has been great. ***knocks on wood***
Dec 14, 2006 | 01:45 AM
  #94
hey i e-mailed nissan about the bad syncro problems and i'm going to see if they have any suggestions. hopefully if enough people have problems they could recall it. it's a long shot but i can hope, especially since my car is out of warranty. oh i've got a question don't know if it has been answered already but would new shifter bushings help at all
Dec 14, 2006 | 05:18 AM
  #95
according to Laomax no they would not help. If the culprit is notchy shifting then yes new bushings will help but for a synchro problem theres no way they would help. Post on here when Nissan gets back to you. I would love to see what they say.
Dec 14, 2006 | 01:23 PM
  #96
thanks for answering my question and i'll make sure to post right after they e-mail me back
  #97
Dec 14, 2006 | 06:48 PM
  #98
cool thanks
Dec 14, 2006 | 07:17 PM
  #99
Quote: hey i e-mailed nissan about the bad syncro problems and i'm going to see if they have any suggestions. hopefully if enough people have problems they could recall it. it's a long shot but i can hope, especially since my car is out of warranty. oh i've got a question don't know if it has been answered already but would new shifter bushings help at all
Recalls are done when there are safety issues. You are talking about a campaign. Highly doubt it. Only way is to have warranty work done. They don;t throw money just like that replacing trannys.
Dec 14, 2006 | 08:58 PM
  #100
52000 miles here and no crunch/grinding. I did have some difficulty shifting into any gear when it was below freezing a couple of weeks ago.
Dec 15, 2006 | 01:12 PM
  #101
***pointless reply***...I just wanted to be the 100th post
Dec 15, 2006 | 06:57 PM
  #102
85000 no crunch
Dec 16, 2006 | 01:10 AM
  #103
Quote: Recalls are done when there are safety issues. You are talking about a campaign. Highly doubt it. Only way is to have warranty work done. They don;t throw money just like that replacing trannys.
figured that was probably the case, if they say no or i don't get an e-mail soon i'm just going to start looking for a used spec-v tranny ( better gear ratio gives quicker acceleration with our engine)
Dec 19, 2006 | 09:04 AM
  #104
Crunchy on Downshift
Ignore, newbie error
Dec 19, 2006 | 09:05 AM
  #105
Mine crunches pretty consistently on downshift into third.I was actually googling for answers which led me to this forum. It just starting doing it consistently about 3 months ago. I'm at about 46K miles now.
Dec 19, 2006 | 12:08 PM
  #106
I've got 50,400 and I get the crunch when the car isn't warmed up especially. I'm gonna call a local dealer tomorrow or thursday and try to setup an appointment to get it looked at.
Dec 19, 2006 | 03:34 PM
  #107
Quote: With a worn synchro, you can push the collar closer to third gear and once it starts to skim the surface of the gear (usually about 1/4 - 1/2 of the way up) you can feel a vibration and hear a noise as well...
I tried mine on the way home from work...mine does this and you can feel it vibrate and hear it. I can basically do that whenever I please...however when I'm at a stop and rev the motor even to 5k and slip it into 3rd its perfectly smooth :dunno:
Dec 20, 2006 | 11:12 AM
  #108
Appointment next week
I called a local dealer, they confirmed I'm still in powertrain warranty and I made an appointment for next week....I'll keep you posted.
Dec 21, 2006 | 02:02 PM
  #109
69,500 miles and no crunch, unless of course I neglect to push the clutch in all the way!
Dec 21, 2006 | 08:47 PM
  #110
Quote: figured that was probably the case, if they say no or i don't get an e-mail soon i'm just going to start looking for a used spec-v tranny ( better gear ratio gives quicker acceleration with our engine)
that's actually a very good idea. Number one, you can get a spec-v tranny for MUCH cheaper than a 5.5 gen tranny, and as you mentioned they do have a shorter FD. However, you will have to use the maxima's bell housing, which won't be too much trouble, but I just thought I would throw it out there...
Dec 22, 2006 | 12:33 AM
  #111
I have a someone similiar issue...well tranny issue at that. My transmission been fine since i got it replaced at 58k, and today jus out of no where my car is stuck in 3rd gear with no chance in hell of coming out. I have not even driven it hard since it got installed, now i''m at 66k and this issue has arise'd. Goin to the dealer tomorrow since the extended my warranty to 72k Since it got reaplaced. Anyone ever had this issue??? Oh srry to but in but does anyone have a connect for flywheel and 6puck clutch?? Since umma replace the tranny i'm goin change the fly and clutch to go wit it.
Jan 3, 2007 | 03:43 PM
  #112
54k miles on an '02 and I get the crunch (i'd call it more of a chatter) fairly frequently when upshifting to 3rd. Doesn't happen for any other gears and usually doesn't happen even in 3rd if downshifting. The entire clutch assembly (flywheel, pressure plate, etc) has been replaced for a different issue and this still occurs. If I pause for a second in neutral between 2nd and 3rd it won't happen either.
Jan 3, 2007 | 04:12 PM
  #113
Ok I've got an 03 SE 6spd with 78000 KILOMETRES on it, I don't think my car has this problem. How would I know? Anyone have the abililty to explain it clearly? If it's there, I'm going to jump on the extended warranty while I've got the chance. Thanks.
Jan 6, 2007 | 01:58 AM
  #114
+1 on th synchros..
http://forums.thevboard.com/viewtopi...t=transmission
Jan 7, 2007 | 07:44 PM
  #115
i get that grind sometimes when the car is cold. it takes a little more effort to push the stick into gear, especially i dont press the clutch all the way in. embarrassed me a few times, but once operating temp is reached no problem.
i also find it hard to shift into gear when the engine is cold, nothing major.
Jan 8, 2007 | 07:15 AM
  #116
for the past month, mine just seemed to disappear...I changed my shifting habbit alittle so I dont know if its b/c of that
Jan 13, 2007 | 08:57 AM
  #117
Quote: @ 78,000 miles now - never had a problem with 3rd.
Same here! Getting some -32 and colder up here in Quebec during winter and never had a problem with 3rd gear or any other gear.
Jan 29, 2007 | 07:54 AM
  #118
No crunch, grind, bump, anything....just over 91k.
Feb 1, 2007 | 09:03 PM
  #119
Hey All,
Just picked up an 02 6 Speed and thought I was hearing/feeling a crunch. At first I just thought it was in my head, but I soon realized this was an occassional problem.
For me it seems to happen more when it's cold, and sometimes it'll grind no matter how long I take to shift.
My car currently has 43K on the odometer, and only came with a 2.5K extended warranty from the used car dealership. I've heard people talk about a 60K Powertrain Warranty. Do you know if this was transferable? I'm only the 2nd owner (3rd if you consider the dealership).
I want to know if I need to address this with the used car dealership, or if I have time to address it with Nissan later.
Thanks,
- Zack
Feb 2, 2007 | 01:59 PM
  #120
I have about 57k on and no real noticable crunch. sometimes it will give a little noise but only i notice it because i have been watching this thread/issue for a while.
