Ignition misfire codes, need some recommendation!
Old Dec 26, 2006 | 02:34 PM
Grey00lustre's Avatar
About a month ago I got check engine light which came up with P1320 - Ignition Signal and P0304 - Cylinder 4 Misfired Detected. So I end up replacing the cyclinder 4 ignition coil. About a week ago the light came back but this time is just P1320. Should I have just replace all 6 coils with the updated ones? I didn't do that at first because it said I only have cyclinder 4 misfire.
Old Dec 26, 2006 | 02:49 PM
OC guy's Avatar
2002 maxima se
ya thats the signal where it tells you to replace all the coils with updated ones.
Old Dec 26, 2006 | 03:42 PM
Matt_01SE_20th's Avatar
erase it and see if it comes back. I had the same issue and replaced 2 of them that were throwing misfire codes and bought an extra for each bank in case another goes but its been almost 2 years and still none have failed beyond the original 2
Old Jan 2, 2007 | 07:51 AM
So you guys suggest I should just replace all six? I just want to make sure before buying it.
Old Jan 2, 2007 | 09:20 AM
bigfatty's Avatar
Booyah grandma.... BOOYAH
See the thread in my sig, I am a firm beliver in replacing only what you need to. I replaced only 2 over a year ago and not had one problem since.
Fat
Old Jan 2, 2007 | 01:38 PM
madisonmxma's Avatar
yes, test them out before you replace all of them. I haven't had any experience with a p1320, but is that code a ignition coil code for sure, or could it be a problem with the signal from the crank/cam sensor?
Old Jan 6, 2007 | 05:14 PM
kdaullary's Avatar
I Have seen soooo many of these codes at the dealership replace all six and be done or you can do ujm 1 at a time for the next year.....
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
