40 series on 19inch rims (please help)
Old Dec 28, 2006 | 03:00 PM
Forevermax13's Avatar
Has anybody tried to put 40 series tires on 19x8wheel on a 2000se? I was wondering if it will fit. because ever site i've been to suggust 35 series.Some of my fiends in my car club say it will fit,but i need to find out from someone who has a max, or little bit more about rims and tires ,what would you advise .Can some one please help me? THANK YOU
1.tire:235/40/zr19 if that does not work I will go with 235/35/zr19
2.car not lowered
3.0 off set
Old Dec 28, 2006 | 08:28 PM
irish44j's Avatar
retired moderator
good chance they will NOT fit, plus your speedo would be off.
It depends on: 1. width of tire
2. offset of rim
3. if you're lowered or not
I run 40 series on my 18x8s (235/40) and come VERY close to rubbing.
The real question is: "if every site you've been to suggest 35 series," then why do you want 40-series, exactly?
Old Dec 28, 2006 | 10:32 PM
sciff5's Avatar
2. offset of rim
35 series would be tiny most likely (depending on how wide the tire is). Would deff make for a harsh ride and it would increase the chances of bending the rim. 40 would be better but prob wouldent look that great on a rim that big
Old Dec 28, 2006 | 11:01 PM
maxspeed96CT's Avatar
The original VQ...
people fit 20s with a 35 series tire, so i dont see why a 40 series 19 wouldnt fit.
Like posted above . it depends on the width of the tire (225 - 245), your drop, and rim offset.
Old Dec 29, 2006 | 04:04 AM
LeX's Avatar
LeX
Nissan by Nature
I was running 235 35 19 on my 02 with absolutely no problems.. i have no idea why 40 series would rub, 35 came nowhere near rubbing (40eta offset on rims)
Old Dec 29, 2006 | 10:26 AM
02theMax's Avatar
I've got 245/40/19 in the rear and they do rub on the right side on big dips. I still have yet to recenter the beam which I think is the culprit. My offset is 33. HTH
Old Dec 29, 2006 | 10:29 AM
2001BLKSE's Avatar
i think what would matter more would be the width of the tire. on my max i had 245/35/20 with no problems. i think 235/40/19 should be fine it will be about the same dia. at the 245/35/20...and i never rubbed unless i had to oafs in the back.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Luigi623
Sep 21, 2015 01:42 PM
0m3nc0w
Sep 11, 2015 05:21 PM
