Technical glitch w/ windows
Old Jul 3, 2001 | 06:59 AM
pjandres's Avatar
This is not normal. With your car running, all windows closed, begin lowering your driver window. As it is lowering, quickly shut off the ignition and remove your keys. At this point the car should be completely turned off, right? Notice however that you can still control all your windows. Not good. I thought Windows problems only belonged to Microsoft.
Old Jul 3, 2001 | 07:07 AM
sixman
Power will remain for the windows, sunroof, headlights, etc for 45 seconds, or until either the driver's or passenger's door is opened. Beleive it is mentioned in the owner's manual.
Old Jul 3, 2001 | 07:20 AM
JKiMaxAC's Avatar
yup six is right..
they wanted to b like most luxry car's letting the power run with out the key in.. most high end cars have it..
Old Jul 3, 2001 | 07:25 AM
AdamK's Avatar
Yah so if you turn off your ignition you still have time to close your windows. When you open the door however, it will disable power to windows. You don't even have to turn off ignition at same time with windows, you can take keys out of ignition wait like 30 seconds and then open windows will still work...
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
