Spark Plug Question
Old Jan 8, 2007 | 10:05 PM
SilverGLE's Avatar
I'm watching you, boy...
Spark Plug Question
I know it's been asked before about spark plugs, but here goes anyway... I plan to pick up some NGK platinum's from Advance Auto Parts. My question is, what is the difference between these 2 plugs:
1. NGK BKR5EGP, G-Power Platinum, $2.98/each
2. NGK PFR5G-11, OE Style Laser Platinum, $9.98/each
Also, would it even be worth it to consider iridium's, either the cheaper ones or the OE style? I'm leaning towards the G-Power Platinum... Any thoughts and opinions would be appreciated!
Old Jan 8, 2007 | 10:06 PM
Progress's Avatar
It's business time.
Get the stock plugs and avoid all hassles.
MaxBoost925's Avatar
Drug Money
I bought OEM Nissan NGK's from the dealer... They look pretty good to me
Old Jan 9, 2007 | 05:49 PM
MacGarnicle's Avatar
Just buy stock! jesus..
Old Jan 9, 2007 | 07:18 PM
OC guy's Avatar
2002 maxima se
get NGK iridium. they are best and inexpensive.
Old Jan 9, 2007 | 07:50 PM
ToneG
Nissan also suggests the Bosch platinums
Old Jan 9, 2007 | 07:57 PM
MaximaGT-R's Avatar
I'm a Happy Man!
i would suggest getting the stock platinums and call it a day.
Old Jan 9, 2007 | 07:58 PM
OC guy's Avatar
2002 maxima se
nissan cant do that. bosch is german i think.
Old Jan 9, 2007 | 08:32 PM
NmexMAX's Avatar
dot dot dot ...
Nissan would never do that
Old Jan 9, 2007 | 10:12 PM
SilverGLE's Avatar
I just went with the G-Power plugs... I can't justify spending an extra $6/each on platinum plugs because they're labeled "OE" unless there's some clear difference between the 2...
Old Jan 10, 2007 | 10:59 AM
madisonmxma's Avatar
There is a clear difference between the two, I couldn't tell you the exact difference but it's worth it to put in the ones the manufacturer recommends. In my old max I decided to go the cheap route with plugs, and down the line a had a misfire, it was the plugs. They weren't the ones the manufaturer recommended. So in the end I had to buy the expensive ones anyways, and had to throw the cheap plugs in the garbage. Complete waste of money.
Old Jan 10, 2007 | 11:49 AM
NmexMAX's Avatar
dot dot dot ...
I use coppers :yay another SP thread
Old Jan 10, 2007 | 04:38 PM
UncleMax98's Avatar
The G-Power plug has Platinum on the center electrode only. The OEM Laser Platinum has Platinum on both center and ground. Double Platinum plug lasts longer.
Old Jan 10, 2007 | 06:37 PM
00MaxSE's Avatar
Pointy Elbows
http://forums.maxima.org/showthread.php?t=232385
Old Jan 10, 2007 | 08:23 PM
mist max2000's Avatar
pretty sure these "2. NGK PFR5G-11, OE Style Laser Platinum, $9.98/each" are what comes out of there,.. and those are what u need to put back in,.. i was stuipd and bought the 3 dollar ones and she just wouldnt run right so i had to pull em all back out and go back to the store and get the expensive ones,.. IMO car ran like **** with the 3 dollar ones
Old Jan 10, 2007 | 10:38 PM
SilverGLE's Avatar
Ah, that's the response I was looking for! It's a moot point now, I just replaced the OEM's with the G-Power earlier tonight.
My car ran just fine the 3 miles I test drove it... Seemed to have more "pep" with the new plugs.
Yeah, I already read that... But I didn't see anything about OE Platinum versus G Platinum.
Thanks for the responses everyone!
Old Jan 11, 2007 | 04:44 AM
Pugman's Avatar
I would get the stock plugs and not worry about it.
Old Jan 11, 2007 | 03:51 PM
ToneG
Check out their courtesy parts site and/or ask at the parts counter.
Old Jan 11, 2007 | 05:27 PM
OC guy's Avatar
2002 maxima se
perhapes but no one uses bosch plugs in nissan on here.
Old Jan 11, 2007 | 07:35 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I used Bosch foe a while and there is no comparison against the NGK.... went back to NGK....... way better IMO
mvm062
Nov 30, 2020 09:00 AM
knight_yyz
Nov 6, 2015 02:34 PM
chernandez1278
Sep 16, 2015 01:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
