Engine Leaking Oil? VQ35
Went today to get my oil changed at a reputable import car repair shop, when they had my car on the lift draining the oil (I was with them the whole time) they saw oil on the bottom of my transmission and the motor.
The mechanic there who is also my friend told me it was the rear main seal leaking. Also knowing that the vavle covers are problematic I chacked them over with a fine tooth comb and no sign of oil anywhere. Its only on the ver bottom of the motor.
BAD NEW IS MY POWERTRAIN WARRENTY JUST RAN OUT 587 MILES AGO!!!
So I went to nissan and they said 11 hours labor minimum!!
Anybody else expierence this problem or have possible solutions???
Im on the verge of trading the car in for a 350z.
Thanks all -chris-
Thanks all -chris-
Originally Posted by DcMaN
yea its a pretty big job
Did you cehck the rear valve cover? So, you took the intake manifold off since you cannot check it with a fine tooth anything with the intake manifold on.
Originally Posted by 2002 Maxima SE
587 miles should be "good will". I'd contact NNA and see if they will cover it.
They don't have much.
Thanks all -chris-
Thanks all -chris-
As folks have said in the forum, talk to NNA and tell them your case, I have a friend who has an Odyssey and he got a rebuilt transmission from Honda at 82K miles, warranty was 80K miles.
FYI, I have the very same leak though I am way off the warranty. The leak is not messing up my driveway but then it is over the transmission.
I was quoted by AAA car care center as a 7 hr job to remove the entire oil pan and resealing with liquid gasket. Others on the forum have recommended to locate the leak and apply sealant from the outside where the pan meets the block. It is pretty tough with the crossbar and all the other stuff around.
Trust me it a labor intensive job and should be done by removing many hardware in the path. BTW, I have never understood why it would leak in the first place since it is a non-moving part that is bolted to the block. I hate these liquid gaskets, why not put a real gasket like the one on the tranny or the oil pan -- way to make money for the stealerships on high mileage vehicles, right!!!
I was referring to the rear main seal being a pretty big job.
To get the Aluminum pan off, you need to get the exhaust and cross member off, pretty intense I would guess.
Well this weekend im going to do my own extensive study of the motor from underneath. Im also going to remove the **** plastic cover from the motor and see if its the valve cover, but im sure its not, ive had a bunch of people look at it already and the whole top of the motor is clean as a whistle.
Im currently trying to find the nissan customor service number so I can beg them for a out of warrantey fix. Not sure how im gonna word it to them, either yell and scream or ask real nicely. Other people told me to keep calling and give them hell and theyll finally give in. Anyone have the number for them?
Post#17
I thought you already did that?
Post #1
Post #1
Well was on the phone with nissan for about 30 minutes today and there gonna get back to me they said within 2 business days. I explained how it was probably leaking before I was out of warrantey and they seemed pretty understanding about it all.
Hopefully theyll call back with good news!
I've got an oil leak...help me find it
bump b/c I did not want to create a new thread.
This is scary...I checked the oil yesterday morning and it was right at the "H" mark. I drove to school and came back. MAX miles put on must have been 7 miles round-trip. I checked the oil this morning and its noticeably lower than the "H" level. The engine itself was replaced by Nissan and only has 3200 miles on it and I KNOW I couldnt have burned any in that 7 mile trip...absolutely not. Burning would mean I have a piston rings problem. Even people whose cars burn oil would never burn oil in a 7-mile period...
So this leads me to believe I have a leak somewhere. I read the rear valve covers usually crack. Thing is, Im sure I got new valve covers when the engine was put in so I'll cross that out as a possibility. I see no oil spots on the driveway. All I could think of is the PCV valve...after lots of searching on here on PCV valve's I have come to the conclusion that it MAY be that. But the only problem is my pcv was replaced 10k miles ago so I highly doubt its that also...
Im stumped now
. What I want to know is if there are any other places I could check for a leak tomorrow?
Im stumped now
I had a greasy tranny bottom when I brought my car. The Nissan dealer checked my car and told me that my tranny cooler line was leaking. So I'm waiting for the parts which will be available on Monday.
lol...well Im gonna check my engine thoroughly for oil leaks in a bit starting with the valve covers and pcv valve...I only hope I isolate the problem to those areas and no where else
ftr, to the OP: It's probably not the actual rear-main seal, it's more than likely the rear upper oil pan seal that attaches to the rear main, even the VQ35 that I picked up w/44k was beginning to sweat oil from it. Oil pick-up o-rings, front and rear oil pan seals, permetex grey, and a lot of time to drop crossmember and exhaust, it's all in the fsm.
^ thanks man but I doubt its the rear oil pan seal b/c I see no oil on my driveway
I was gonna get ready to diagnose the leak today but realized I dont have my tools on me. Its so much harder w/o them so I wont even attempt it...Im just going to take it to Nissan. Besides the upper oil pan seal what else can I tell Nissan to check?
More than likely its not the rear valve cover b/c its a new engine and Nissan gets the engine in 1 complete piece so Im guessing theres already a new one in there
OP means Original Poster, I wasn't referrng to your leak.
Sllvermax, Did you check for oil residue in the exhaust tips, pcv or rings would cause that, pcv would also be more likely to cause idle issues as well. Rear oil pan seal will cause wetness around the bellhousing.
$500 is steep if it's the rear oil pan seal, which it almost always is, however if you're pulling tranny and supporting engine with hoist to do the entire rms the proper way that's a very fair price.
6spd4dsc
Mar 4, 2016 05:19 PM
kjlouis
Oct 3, 2015 05:29 AM
03VQMAX
Sep 5, 2015 03:47 PM
