engine rebuild?
Old Feb 5, 2007 | 07:02 PM
maximaownsyou's Avatar
engine rebuild?
i have the oil conumption issue in my 5.5gen.... ive heard its the piston rings allowing blowback. how much would new rings be in relation to a rebuild?
Old Feb 5, 2007 | 07:17 PM
DOHCtorJT's Avatar
Rings $100 if that. Labor, over $1000 easily.
Old Feb 5, 2007 | 07:18 PM
twitch579's Avatar
Get on your back and check the bottom of the motor for leaks, I had the drinking oil issue too and thought it was the motor just burning oil or whatever. When I got my oil changed 3 weeks ago the mechanic noticed oil under my transmission and motor where they meet, I took it to nissan and they told me I have a rear main seal leak and its 11 hours labor to fix it!!!!
Also the best part is... IT will not leak when parked even overnight, so youll never know unless u crawl under the car and look. It mainlely only leaks when u are driving.
Also this happened to me right as I hit 60,500 miles. Fresh out of warranty!!
Old Feb 5, 2007 | 07:24 PM
MaximaGT-R's Avatar
I'm a Happy Man!
twitch how much did they quote you for the job?
Old Feb 5, 2007 | 08:05 PM
twitch579's Avatar
11 hours labor plus parts. I basically walked out pissed and havent been back, when it gets worse ill have to get it done or clean off the oil and trade it in.
Old Feb 5, 2007 | 08:09 PM
upstatemax's Avatar
Nissan is trying to F*ck you...
If it is that bad and Nissan will not help, just trade her in and get something else.
Old Feb 5, 2007 | 09:48 PM
joebangaa's Avatar
damn you already got a leak?? that sucks. i'm almost at 60k miles and really hope my ride doesn't need any major work once the warranty is gone.
Old Feb 6, 2007 | 12:15 PM
SoonerFan's Avatar
Cletus
a 3.5 with an oil consumption problem??? NEVER!!!
i know mine is the rings.
Old Feb 6, 2007 | 06:59 PM
thats where i got the info from, your almighty thread... i did have slight oil looked like where the tranny bolts together but it looks old and dried up... like it was a problem and fixed but never cleaned off.... took off my crappy oil catch can (clogged up my pcv valve... hose full of oil ) so we will see if that has any effect. also going from 0w30 royal purple to 5w30 mobil 1.... lets see if that helps as well.......
bah... just when i got my idle fixed and was all happy..... why cant this ever end?
Old Feb 6, 2007 | 08:48 PM
Love_00_Max's Avatar
I too have the rear seal leaking but with close to 120k on my odometer. I was quoted 7 hrs to remove the aluminium pan and re-seal it with liquid gaskets, never really understood why these things leak in the first place (oh yeah it does leak right after 60k, isn't that wondeful).
The oil consumption on my vehicle is neglible, I will live with the leak till it gets messy and the oil loss is noticeble.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
maximusrising
Sep 2, 2015 09:55 AM
