Rims/tire Sizes Help!!!!help Please!
Hello all Max stunnas/lovers. I have Eibach Pro-Kit, Tokico Blues HP and currently running on stock 16" SE rims. I need to change rims and i'm looking at a set of 17's on tirerack.com . If i used 17x7.5, what tires size is best for my car without rubbing and if i use 18x8, what tires size should i use. Any replies would be appreciated. Thanks.
does this help:
http://www.miata.net/garage/tirecalc.html
I have eibachs with 18x8 OZ rims with 235/40/18 Sumitomos and there is plenty of room. when my tirethread wears though, im thinking of getting 245s. everything is awesome with the 235s but i still think the tires look too think from the front or back view. well, hope this helped. what rims and tires you buying?
Try Discount Tire Direct
Check out www.discounttiredirect.com I think they have a better selection, plus they have the Konig Tantrums and Verdicts which would look cool on the Max.
Re: Try Discount Tire Direct/Help
DUNLOP SP SPORT 5000 BLCK P235/45ZR-17
KONIG TANTRUM 17X7 5-114.3 40S
Re: Re: Try Discount Tire Direct/Help
Originally posted by Deven2kStickMax
HELP. Does anyone knows if this tire/rim setup can work good with Eibachs? I need to know if it will rub on the fender and there will be clearance. Please reply someone. I want to buy them by discounttire.com
hmmm....the Konigs are 17" x 7". I don't think the tires are meant to be mounted on 7" wide rims. You may want to double check though. For 235 series tires, the rim should be 7.5" wide for most cases. Look for some 7.5" or 8" wide rims for the most choice in tires. People have mounted 235's on the stock 7" rims without any problems yet, so it may be ok. But I don't think the tire manufacturer would recommend it.
Re: Re: Re: Try Discount Tire Direct/Help/Selling Stock 16 $500.00
Re: Re: Re: Re: Try Discount Tire Direct/Help/Selling Stock 16 $500.00
ok I ordered set of Dunlop SP 5000 P235/45/17 and set of set of Konig Tantrum 17x8. I hope this doesn't works good with the Eibachs.
Sounds like a tight setup
Post pics when you get the chance....
knight_yyz
Nov 1, 2015 01:34 PM
