00 Ignition switched locked
Old Feb 17, 2007 | 08:26 AM
DoNcHoYaX1's Avatar
The ignition switch locks itself once in a while. The most time I spent trying to unlock it is 5-10 minutes, just by turning the wheel one way and another and trying to turn the key. I mean I could just turn on the car turn it off, I dont even move it from the parking position. I try turning it back on and wont even turn the key. Any suggestions?
Old Feb 17, 2007 | 08:48 AM
kenshi's Avatar
Wiggle the steering wheel when turning the key?
Old Feb 17, 2007 | 08:50 AM
DoNcHoYaX1's Avatar
Thats what I do to start it up, but I want to know should I take it to the dealer, or just buy the ignition switch and replace it? But then what about the keys since we have the chips in them.
Old Feb 17, 2007 | 08:53 AM
Teddie18's Avatar
It may be a worn key, ignition tumblers or a combination of the two.
Old Feb 17, 2007 | 08:54 AM
MacGarnicle's Avatar
I've had this problem twice now as well.. it's rather annoying. Is there a component failing or just a security device? (i.e. steering wheel lock type thing) Very strange
Old Feb 17, 2007 | 08:59 AM
Teddie18's Avatar
It's a failure of one of the security devices. Meaning it's either the key, the ignition or the steering lock mechanism. All three are parts of the cars security system.
Old Feb 17, 2007 | 09:03 AM
well that's a bother.. thanks for the info teddie
Old Feb 17, 2007 | 09:07 AM
realtor's Avatar
The same thing happened to me with my '98 Quest every time the weather got cold and I see you live in IL. Try some graphite lubricant into the key hole. Hope that helps.
Old Feb 17, 2007 | 09:24 AM
kdaullary's Avatar
crappy to say but i see this quite alot, 97-00 max's have a problem with the ignition lock cylinder wearing out. take it to your shop of choice, have um replace the cylinder and iether rekey it for your existing key or get a new key se. until you do be carefull not to brake your key.
Old Feb 17, 2007 | 11:28 AM
kenshi's Avatar
brake = a device for arresting or preventing the motion of a mechanism usually by means of friction : something used to slow down or stop movement or activity
break = to separate into parts with suddenness : violence or VIOLATE, TRANSGRESS <break the law> <break a promise> : to disrupt the order or compactness of <break formation>
Old Feb 17, 2007 | 11:59 AM
DoNcHoYaX1's Avatar
is there anyway to hotwire itI took apart the housing for the steering wheel, Not it just wont turn so I need to replace it. Nissan quoted me 175, but will take 2-3 weeks to get in so. I want to know another alternative to get it on just to go to work. Anyone, is it even posible to hotwire it, since it has the chip in key.
Old Feb 17, 2007 | 01:32 PM
DoNcHoYaX1's Avatar
can a mod lock the thread I found my answer, I have to replace it.
Old Feb 17, 2007 | 02:19 PM
SoonerFan's Avatar
Cletus
you can delete the thread by deleting your first post
Old Feb 17, 2007 | 06:46 PM
Love_00_Max's Avatar
The 00 Maxima's have poor ignition systems.
I had the very same problem you described, and one fine morning it got all locked up. Had a locksmith come and repair the stuff and paid him $200.
One suggestion that he gave me was quite interesting, don't have any keys with the key bunch other than the ignition key. I used to have my home key, work key(s) etc and this puts a lot of stress on the already weak ignition switch.
Old Feb 18, 2007 | 06:13 PM
kdaullary's Avatar
your a loser do you not have anything better to do than follow me around maxima.org and try and find peoples typos
Old Feb 18, 2007 | 07:14 PM
kenshi's Avatar
That would be "you're a loser," not "your a loser."
Stop being so paranoid. You make it too easy.
Old Feb 18, 2007 | 09:17 PM
^ lol
I've heard this too.. I always use my spare key which has it's own ring with the remote, to start the car. Not stricly to protect the ignition, I have other reasons.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
