hot cold guage is cold when moving. need help
Old Feb 24, 2007 | 07:13 AM
maxfeen's Avatar
i noticed yesterday that when i depress the gas pedal the needle goes down to cold. when at a red light it goes back to the middle. what does this mean?
Old Feb 24, 2007 | 07:33 AM
maj02's Avatar
i have the same problem with my toyota seems like your thermostat is not clossing so when you drive in the highway you can see the thermostat needle drop and you start loosing warm air from the vent and start blowing cold air ....i would have a mechanic take look on the thermostat
Old Feb 24, 2007 | 07:59 AM
maxfeen's Avatar
thanks for the feed back. i was thinking the same thing
Old Feb 24, 2007 | 01:51 PM
tsk808's Avatar
the only time I've seen this is when coasting down a long hill on the freeway, occasionally tapping the brakes only. Apparently so much cold air is being registered, it can't sense the engine heat. Either it's really cold where you are or sensor is messed up. But since it goes up at a light, it is sensing.
Old Feb 25, 2007 | 03:38 AM
lalaMAX's Avatar
it's the thermostat was bad, and it was kept on an open position... so when ever your engine is running, the coolant will keep cycling, therefore it will keep taking out the heat from radiator. symptom will be hard to warm up the car, even tho it warmed up, ones the car gets going, temperature drops. no heat will be blown out even tho u turn your heat to 32C... lucky that it didnt caught on the close position because your engine will over heat!
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
