Timing belt or Timing Chain?
Old Mar 1, 2007 | 07:53 AM
2000SEBlack's Avatar
I have a 2000 Maxima SE. Does this motor use a timing belt or a timing chain? If it is either, when is the correct time for replacement?
Also, anybody have a good procedure for a radiator flush?
Old Mar 1, 2007 | 08:11 AM
Teddie18's Avatar
Your Maxima has a timing chain and it doesn't require replacement as a belt does. If you do flush your radiator don't put pressure on the system. Otherwise you may end up with water on the passenger side front seat floor.
I drain the system of existing coolant and then I run distilled water through the system when I flush the system. You can try to remove the engine block drain screws but they are very difficult to reach if you don't have the proper tools. I then pour in the distilled water until the system runs clear of radiator coolant. Then I refill it with the appropriate coolant. I know there is probably a better way but thats how I do it.
Old Mar 1, 2007 | 08:24 AM
NmexMAX's Avatar
dot dot dot ...
It's got a metal link belt.
Old Mar 1, 2007 | 09:55 AM
Gjohnson's Avatar
Yep, timing chains are suppose to last the life of the engine, but it is possible that after high mileage it might need replacing. I have owned a couple of 240's also and although they have timing chains also, the chains can start to stretch over time and cause chan rattle. I replaced the timing chain on my last pig nose and it was pretty straight forward.
Old Mar 1, 2007 | 09:57 AM
NmexMAX's Avatar
dot dot dot ...
I'd say that's more related to the tensioner than the chain itself.
Old Mar 1, 2007 | 10:04 AM
Gjohnson's Avatar
Yeah, the tensioner is a common problem also.(getting gunky and not expaning as it should.)
But the 240's do or did have any issue with the chains stretching. The chain that I replaced last year, was suppose to be improved for that reason. I also, placed the new and old chain side by side and you could see a difference in length.
Old Mar 1, 2007 | 10:07 AM
NmexMAX's Avatar
dot dot dot ...
So then it alters timing ever so slightly? Or does it stretch like bubble gum.
Old Mar 1, 2007 | 10:13 AM
Gjohnson's Avatar
Well, actually the reason I replaced the chain on the pignose is because it had streched so far that the chain jumped a link and messed up the timing. I bought the car from a small getto car lot for $450, because of the timing issue and they towed it to my house so I could rip it a part.
Old Mar 1, 2007 | 10:28 AM
P. Samson's Avatar
There is the one primary chain with one oil pressure operated tensioner and two guides, and the two secondary chains with one tensioner each, and all lubed with one oil jet.
Old Mar 1, 2007 | 11:25 AM
andy2248's Avatar
Isnt that a Nice thing about newer cars you dont have to replace the timing chains
Old Mar 1, 2007 | 11:27 AM
NmexMAX's Avatar
dot dot dot ...
Not true.
Many still use belts
Old Mar 1, 2007 | 03:37 PM
nismopc's Avatar
hmm That's new news to me.
Old Mar 1, 2007 | 03:55 PM
P. Samson's Avatar
Even Honda has gone to chains. Belt replacement became a negative for them because of the competition. Just be forewarned, for the "average" driver, most probably will not have to replace a chain, but if you regularly do a lot of "excursions" towards the redline, that may not be the case.
Old Mar 1, 2007 | 04:13 PM
NmexMAX's Avatar
dot dot dot ...
I was pretty sure they went to chains as of late. What year did they convert?
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
