"Marbles in a can" pinging noise under deceleration
Old Mar 1, 2007 | 01:38 PM
pbn85's Avatar
I actually just noticed this 2 days ago. When Im at low speeds and usually in 1st or 2nd gear and just let go of the gas I hear this "marbles in a can" pinging noise. Under acceleration I can hear the noise also but not as much. When I shift higher the noise goes away. Any idea what this is?
Could it be the heatshield on the cat. converter? Mileage is 53k and car has no other problems. Any help is appreciated. Thanks in advance.
Rahul
Old Mar 1, 2007 | 01:41 PM
upstatemax's Avatar
Look under your car and see if there is a can under your car, the can might have marbles in it.
If there is, remove the can and that should solve your problem.
Old Mar 1, 2007 | 01:45 PM
pbn85's Avatar
if that was sarcasm (which it most likely sounds like) then please take it elsewhere
Old Mar 1, 2007 | 01:48 PM
upstatemax's Avatar
No, I think this pointless thread is a perfect place for it...
Old Mar 1, 2007 | 01:51 PM
NmexMAX's Avatar
dot dot dot ...
Do you have a catch can?
Old Mar 1, 2007 | 01:53 PM
pbn85's Avatar
oh yea...its pointless because Im actually having a problem with my car and Im looking for an answer? Stop spamming my thread with your crap man.
Old Mar 1, 2007 | 01:54 PM
mist max2000's Avatar
i hope you use 93 octane. . .
Old Mar 1, 2007 | 01:57 PM
upstatemax's Avatar
No it is pointless because there are countless threads on here about this SAME EXACT problem....
pbn85's Avatar
ofcourse..93 all the time. I know its not the tranny. I hope the timing chain is not rattling...those dont normally go bad
Old Mar 1, 2007 | 02:04 PM
i disagree...whats normally? theres a TSB on time chain clatter or w/e,.. try to dig it up and see if its your problem
Old Mar 1, 2007 | 04:41 PM
pbn85's Avatar
just drove the car again...problem got noticeably worse
Old Mar 1, 2007 | 04:51 PM
NmexMAX's Avatar
dot dot dot ...
Add a catch can, change to colder plugs
If it is indeed spark knock and not some loose items dangling around, try the above then post back.
Another thing, if it is spark knock,
Old Mar 1, 2007 | 07:31 PM
96SEsleepa
my mechanic said its rod knock. sounds like something is knockin inside the motor. been drivin the car like that for the last 4 months, and nuthins happenned yet.
Old Mar 1, 2007 | 08:40 PM
NmexMAX's Avatar
dot dot dot ...
Ok nice thread jack If it is indeed rod knock you =
Old Mar 1, 2007 | 08:51 PM
platinum03SE
uhm its def. not rod knock. hey silvermax i have the same problem. ive came to the conclusion that it is something in the exhaust. it only happens to me when my car is fully warmed up. i can make the rocks in a can noise by just reving my car up to maybe 1500rpm to 2000rpm. when its cold and i give it a little rev i get no noise. im thinking something in the exhaust since its stock.
edit: i just noticed my car is like a twin to yours. im just at 51k thou lol
Old Mar 1, 2007 | 09:07 PM
danger300z's Avatar
allot of maximas 3.5 have this problems
Old Mar 1, 2007 | 09:27 PM
pimpin02max's Avatar
Whoa, I have the exact same problem, in cold weather it doesn't do it until my car is fully warmed up. I rev to about 1500-2000 rpms and when I let off it starts rattling. I think that it may just be the Pre-Cat rattling though. I have had this problem for a while and like you guys, my car has around
50-60k miles. My car still runs fine and everything, and BTW I have an aftermarket exhaust and it still does it. But I think maybe this is just a little petty problem that most Maxima owners have, but I am not for sure.
Old Mar 2, 2007 | 03:31 AM
pbn85's Avatar
my old 01 prelude had a similiar noise and it was the cat converter. it was replaced by honda for free. But the only difference was when I revved at idle I could hear it with that car....when I rev this one I get no noise
Old Mar 2, 2007 | 06:22 AM
Imax00's Avatar
hey rahul your not selling the car no more...we met at erskine back in oct. i had a red 5thgen
Old Mar 2, 2007 | 06:26 AM
NmexMAX's Avatar
dot dot dot ...
404 Error, relavance to thread not found.
Old Mar 2, 2007 | 06:28 AM
Imax00's Avatar
Yep, very relevant also to THIS thread also.
spark plugs.'s Avatar
Hi, I drive a Maxima.
why be a ****? if you don't have a useful answer, GTFO.
Old Mar 2, 2007 | 06:30 AM
I'm not sure about max's, but in honda's it's very common for the heatshield on the cat to come loose and cause this same problem.
Old Mar 2, 2007 | 06:31 AM
NmexMAX's Avatar
dot dot dot ...
Car's wacked, he tries to sell, no noe bites, he's interested in fixing
In our case, the AFR becomes lean, fries the cat, and creates it to break apart, causing said noise.
Old Mar 2, 2007 | 06:32 AM
platinum03SE
ya but its coming from the ypipe area. your mod list doesnt have one. im pretty sure thats where its coming from. im about to take a hammer and start hitting the heat shields and whatnot.
Old Mar 2, 2007 | 06:33 AM
platinum03SE
so YOUR saying its the cats rattling?
Imax00's Avatar
i guess well have to see.
Old Mar 2, 2007 | 06:37 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by platinum03SE
so YOU'RE saying its the cats rattling?
Not on my car, so I cannot say for sure.
But since the OP hasn't provided a detailed description, I'm shooting in the dark.
Old Mar 2, 2007 | 06:51 AM
platinum03SE
damn i really want to know if a ypipe or a set of headers and yipe will fix it because that **** really pisses me off.
Old Mar 2, 2007 | 06:56 AM
Bones45's Avatar
So instead of being a douchebag.. which obviously you are..why don't you help the guy out?
Old Mar 2, 2007 | 06:57 AM
criddle20's Avatar
I know I have a lot of street cred around here with this being my first post but it I agree with the above quote... something in the exhaust, possibly the Cat. Does it smell funny like anything you would expect with a bad cat?
Old Mar 2, 2007 | 07:07 AM
upstatemax's Avatar
I have plenty of answers for him, but he needs to search and do some common problem solving like even finding out where the sound is even comming from before ANYONE can really help him.
People are way to lazy of this board, "ohhh I heard a sound, I will go post about it and expect answers to be feed to me without any work on my part"...
The 5th gen forum is full of repost because of people like the OP who don't do anything for themselves.
Now his little friends from NYCMaximas can come in and "call me out"...
Old Mar 2, 2007 | 07:09 AM
platinum03SE
i DONT think its a cat also. for a cat to be failing at 50k would shock me for a STOCK vehicle. if the cat were bad there would be some sort of rank smell. also, if there were a bad cat, it would have definitely effected the performance of my car.
edit: honestly get the **** of if your going to be a douch bag.
Old Mar 2, 2007 | 07:42 AM
criddle20's Avatar
Just because the cat is rattling doesnt mean performance will be effected and it doesn't have to produce a bad smell, that is just a sign of a bad Cat. If you melted it by using regular unleaded or something like that you would notice a difference in performance, but not if some of the guts of the cat are just rattling. A cat CAN go out at anytime from just about anything or for no reason at all so the fact that there are just 53k miles on the car doesn't really matter. Just my opinion, if you don't agree or whatever that's fine. And I really hope you aren't calling me a dooshbag, I'm just trying to help out. I had a cat go out on an 04 Jetta with 21k miles for no reason at all... ran the recommended premium unleaded and everything. No bad smell, just rattling in the exhaust when accelerating or decelerating (Downshifting). Just giving my 2 cents from experience.
Old Mar 2, 2007 | 09:03 AM
platinum03SE
no no your not the douch bag lol
i duno im gonna take the cats off soon and look.
Old Mar 2, 2007 | 09:22 AM
NmexMAX's Avatar
dot dot dot ...
The 2 of you posting back and forth is like Ray Charles leading Stevie wonder into an intersection.
A bad cat will hurt performance. Especially fro an 03 where the cats are integrated into the exhaust manifold They affect it as it is in stock functioning form. Proof of this is aftermarket headers.
Explain to me how in gods good name you can do that by using regular unleaded?
Again, refer to my first sentence in this post.
True in a small %. What's not true is the any reason at all part. A cat doesn't just go wrong, it is prompted from something else. Read this link for more information. http://forums.maxima.org/showpost.ph...4&postcount=13
. You're not helping here since 99.98 % of the information you posted is incorrect.
Ok, this is Maxima.org.
Prepare to be shocked because only 50% of what you said is correct, and you're incorrect on the shocked portion. But you're correct in that a bad cat will affect performance
Old Mar 2, 2007 | 09:27 AM
pbn85's Avatar
wacked? This problem just happened few days ago. I had to sell for person reasons and now the situation changed and I get to keep it. I have one of the best maintained 5th gens...this problem just happened outta the blue.
Update: seems like the noise died down a little but Im still taking it to get checked out tomorrow. I hope its not the timing chain
Old Mar 2, 2007 | 09:31 AM
pbn85's Avatar
go talk to the many people who make threads on suspension related issues and then get back to me. okthanksbye
few more details on the problem:
-NO smell
-NO noise when revving at idle
-car still performs the same
-I cant think of a better term than "marbles in a bag" to describe the problem
-Looks like its an on/off problem.
I'll let you guys know what the dealer says tomorrow. Thanks to those who gave productive advice
Old Mar 2, 2007 | 09:32 AM
NmexMAX's Avatar
dot dot dot ...
It would be nice if you were more familiar with your 'sounds' recognition. Exhaust rattle/spark knock/ping /rod knock/ chain rattle are all pretty distinctive.
Anyhow, good luck in your repair venture.
Old Mar 2, 2007 | 10:17 AM
MaxBoost925's Avatar
Drug Money
-NO smell
man so many laaazy newbies here...
http://forums.maxima.org/showthread....highlight=bees
http://forums.maxima.org/showthread....highlight=ping
http://forums.maxima.org/showthread....light=knocking
use the search
