BCM Location
Mar 1, 2007 | 03:25 PM
I just bought a "beep module" which makes my lock and unlock noise a beep instead of the stock honk. I was wondering if anyone knows where the BCM is and maybe which wires to hook into. I found two that work but it also will make it beep when you unlock the door from the switch in the car. TIA
Mar 1, 2007 | 04:03 PM
i believe the bcm is in the dash behind the radio, not sure on the wires, my friends 96 max was behind the radio not sure if its the same on the 5th gens, hope this helps at all
Mar 1, 2007 | 04:10 PM
that is what i thought to but when you unplug it it doesnt effect the remote. There are 2 boxes behind the radio; TCM and that other one.
Mar 1, 2007 | 05:09 PM
yeah, im almost 100% that other box is the bcm, he had a window/door lock problem which could be the same device that you need to tap into, his was called the In-Vehicle Multiplexing System IVMS. electrical signals supposedly go through that and the bcm. maybe its that device that you need? hope it helps, i dont know the details on that IVMS system though sorry
Mar 1, 2007 | 05:13 PM
Thanx for the help
Mar 1, 2007 | 11:07 PM
hey let us know if it works...and give us a write up!!!
