led power
Old Mar 1, 2007 | 03:37 PM
inspiredbykev's Avatar
You should thank my D***
led power
whats ups fellas,
So I finally finished doing the window switch leds metals way. Only problem he says to tap into the red w/ white strip wire. I tapped into the the only think white w/ red stripe wire thinking this was the one on the bigger harness but the leds stayed on constant. I dont see the red and white wire that he shows in the pic post #47 http://forums.maxima.org/showthread....&highlight=LED Is that located on the smaller harness?
I don't know if the colors are different because I have a 2k2.
Thanks,
Kev
Old Mar 2, 2007 | 12:54 PM
playboi21617's Avatar
i bought an LED dome light for my 02 max and when i put the switch in the middle to make it come on when the doors open the light stays 1/4 of the way. and never goes off and then i put some in map lights and those dont come on at all. I bought them from autoillumination.com and they told me to switch some wires around but there arent any. Holla back
Old Mar 2, 2007 | 01:13 PM
sweetjackal82's Avatar
YEP... MINE TOO...
after 2-3 months the led dome light blew and it dont work no more... $10 wasted
Old Mar 2, 2007 | 03:13 PM
bump to the top
anyone else do it metals way
Old Mar 2, 2007 | 03:37 PM
Revs2Hard's Avatar
BARF
I would pay someone to do all the interior lights in my car blue.
Old Mar 2, 2007 | 04:04 PM
MIXXMAX's Avatar
Originally Posted by inspiredbykev
whats ups fellas,
Thanks,
Kev
If you're talking about tapping into the power wire for illumination, the wiring scheme is different from the earlier 5th gener's ('00) as compared the the later 5th gener's ('02 and up). For the 2k's, the power wire for illumination for the driver's window switch is red with white tracer. For 2k2's, the power wire for the illumination wire in the driver's window switch is white with blue tracer (if I can remember correctly).
Old Mar 2, 2007 | 04:43 PM
is it on the small harness or the larger harness?
Old Mar 3, 2007 | 06:50 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
i like how the thread was hijacked reallllll quikly... btw sorry i don't know the answer to ur problem... my d.s main window switch light no longer working have the led swap lol... but the others are vonderful... try tapping into the led solder from the original bulbs it self... hope that helps...
doctorpullit
Oct 28, 2019 10:58 PM
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
leatherneck
Sep 30, 2015 09:16 PM
