Sub stopped working
Old Mar 4, 2007 | 02:10 PM
Progress's Avatar
It's business time.
Sub stopped working
It's been cutting in and out either working or not. It hasn't been working for a week now. I checked the wires on the sub itself and nothing looks frayed.
Any ideas?
Old Mar 4, 2007 | 02:51 PM
jkmay01's Avatar
Lil 8
there are several things to check, if the sub amp turns on when the deck is on and the amps power cuts in and out could be that the remote turn on wire is not presenting a constant 3v causing the amp to turn on/off. a relay will fix this problem. Another possibility is your power or ground wire to the amp? not a secure or clean ground will cause the power to cut in and out. Is this the only amp you are using? or do you have multiple amps? do they cut in and out? hope this helps?
Old Mar 4, 2007 | 02:58 PM
Progress's Avatar
It's business time.
Thanks. 100% stock Bose setup, BTW.
Old Mar 4, 2007 | 04:12 PM
00MaxSE's Avatar
Pointy Elbows
Oh noes! Good luck with this, Sam.
Old Mar 4, 2007 | 04:39 PM
jkmay01's Avatar
Lil 8
did u do the install of the sub amp? when does the amp cut out? over bumps? if u wiggle any of the power/ground/remote turn on wire(s)? are u using the power attenna lead from deck as turn on for remote wire to amp?
Old Mar 5, 2007 | 09:53 AM
monty31's Avatar
He's using the stock bose setup as stated above.
This is a very common problem to which there has been no solution. Search and you will see.
Cotozic
Jun 28, 2017 08:01 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kenc15
Aug 5, 2015 08:29 AM
